7 members (Doug J, Dek, MJF, TBM, Guern, Ian Wegg, Bunny), 210 guests, and 79 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
Page 3 of 3 1 2 3
Originally Posted by teknome
On my 1995 Plus 8 the alternator bracket is a Morgan item, says Morgan on the bracket, so not a SD1 or LR item
Yes Mike same with My +8. Stuff changed thru out the years I guess.
Button
CJB Offline OP
Great stuff guys, tq.
As I said, not busting urgent fortunately, I'm going to give it some thought. The slot in the valence allows me to get a spanner on the rear bolt and I can get on the nut of the front one with a flexible drive. The problem is the length of the bolt will not allow me to remove it. I may take the grill off and cut a hole that is big enough to take a socket and then withdraw the bolt.
I'm going to Silverstone on Sunday so will be checking out similar age +8's and their owners!
I always fill my new oil filters before fitting and have never noticed a priming issue fortunately but thanks for the warning.
1990 +8 Connaught Green
1970 Lotus Elan S4 SE
1973 Lotus Europa TC/Special
CJB Offline OP
Teknome: Interesting that your bracket is actually marked Morgan, I haven't seen that on mine. SD1 is written on the alternator in felt tip and TVR on the engine!
That's interesting, my 1999 Plus 8 has Morgan on the bracket too as did my 1994 Plus 8 out of interest. Good Luck with the job.
With TVR being on the engine do you think your car has had an engine swap at some time.
My 3.9 has Morgan cast in the Alt Bracket.
Button
My 1994 +8 has Morgan on the Alt Bracket, was able to remove it by putting a socket through the cut out. It's fiddly and patience is required, I agree it is tight against the bodywork but it works.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
CJB Offline OP
I've had the car from new, I guess Land Rover had it originally destined for TVR?
CJB Offline OP
britmog: Did you remove the alternator c/w bracket?
Yes, I removed the c/w bracket
Bruce
2013 M3W (Olga)
CJB Offline OP
That’s the way then, thanks.
Page 3 of 3 1 2 3
