8 members (AMorgan, Luddite, stumog, JohnHarris, JMcL, TBM, Jon G4LJW, Joske Vermeule), 285 guests, and 103 robots.
+8Rich 78
Topics49,872
Posts837,686
Rudolf
Page 4 of 6 1 2 3 4 5 6
RBW #590841 20/08/19 12:16 PM
My 3.0 Roadster will do 32mpg ......on a run.
Regards Mark
2004 Roadster S1 3.0 V6 gone!
Mark
Originally Posted by Fox Terrier
My 2015 GDi gets around 38mpg overall. I’m happy with that. Had the Flash thing done a couple of years ago which made all the difference. Love it!
I'm glad you say that as I have never measured mine , just guessed at it. I'm not sure what the benefits of the GDI are over the previous Duratec but I know it seems to be a good engine in a real car.
Reg
RBW #590989 21/08/19 08:41 AM
X
X
As I collect the MOG in November I was surpriced about the low consumption. About 7 litres/100 Km.
It was cold, wet and slippery, the MOG was brandnew and the hod was closed.
The times changes, spring rises up and also the consumption. Dry road, hod down and up to nearly 10litres/ 100KMs.
Ups... Now with a light right food it's about 8litres a real thing. Sometimes to listen the wonderful "roarrrr" may be it's a little bit more, but less than 9litres.
René
2018 plus4 (sports green)
RBW #593780 06/09/19 07:20 AM
I did a little evaluation after two seasons:
So far I've driven about 20,000 km with my Plus 4. About half of it last year and the other half this year.
I mostly drive on scenic country roads. I avoid motorways as much as possible (total share approx. 1%).
Average consumption total 7.34 l/100 km (38.4 MPG). Tendency falling.
2018:
Average 7.45 l/100 km (37.9 MPG)
Min. 6.34 l/100 km (44.5 MPG)
Max. 8,02 l/100 km (35,2 MPG)
The maximum was at the last tank filling before winter (so it's rather caused by low outside temperatures).
2019:
Average 7,18 l/100 km (39,3 MPG)
Min. 6.66 l/100 km (42.3 MPG)
Max. 7.58 l/100 km (37.2 MPG)
What is interesting for me is that the average consumption this year is significantly lower than last year. The driven roads were quite comparable. This year I have been partly even more sporty on the road (I have discovered that revs over 4000 RPM can be quite fun drive)
Here is a list of average fuel consumption per refuelling:
The first year ends approx. in the middle of the list after the average with 8.02 (l/100 km). The first value with (coincidentally also) 8.02 contains a longer (quite fast) motorway trip.
It can clearly be seen that consumption was higher at the beginning than later. So there seems to be a running-in behaviour.
Michael
2018 Plus 4 Sport
RBW #593783 06/09/19 07:33 AM
Very interesting line-up, Michael, thank you very much. Right at the beginning when the consumption was a bit higher the engine had more friction. It was probably not yet lively and responsive than today after 20.000 km.
RBW #593794 06/09/19 08:22 AM
I rarely get under 9L/100km. Last (motorway) drives it did 10-11L/100km. (Speeds 100-130km/h)
Currently it is at the dealer to get the Immobiliser-problem sorted out. I asked them to check if there is something wrong re fuel consumption.
Hope they find something, consumption is quite high...
Thomas
2017 Plus4
RBW #593826 06/09/19 11:21 AM
I picked up the Aero Racing manifold and full system from the factory on Monday.
I'm still getting low 30's but there's no doubt that my engine has loosened up significantly and is now just over 7000miles.
I never had the original upgrade ecu flash, but once I've fitted the new system, I'll pop back to the factory for the Clubsport flash.
Yesterday I got the exhaust off, but I left the manifold until Saturday because it doesn't just lift out.
Obviously I'll take some pictures and do a How To, as I go.
This way, having done 7000miles with a standard set up, I can compare the new system before the ecu flash, then on the way back from the factory I should get a clear idea of the changes.
RBW #595686 18/09/19 08:19 PM
RBW Offline OP
So after my journey to and from the factory the figures are in:
Travelling to the factory
Distance: 236 Miles
Fuel Used: 26.5 Litres
Brand: Shell V Power (99 Octane Rating) @ £1.45 per litre
MPG: 40.5 MPG
Travelling from the factory
Distance: 208 Miles
Fuel Used: 20.6 Litres
Brand: Esso Supreme+ Unleaded (97 Octane Rating) @ £1.40 per litre
MPG: 46.1 MPG
The journey time was longer coming from the factory due to an accident on the M25, but traffic flow was much faster on the M40 coming home.
Looks like I may be leaving vpower!
2015 Yellow +4
RBW #595701 18/09/19 09:12 PM
I get at least 40 mpg on 95 octane. 14k on clock. No flat spot and no hair trigger accelerator.
All in a very well behaved motor.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
SteveT #597752 02/10/19 07:53 AM
Originally Posted by SteveT
Originally Posted by Jon G4LJW
Originally Posted by Deejay
Librands advertise their manifold complete with ceramic cat for £1360 plus vat and delivery. I had a remap done at Williams about 5 years ago and it was £400 then, so looks as if it approaches £2k overall and even more if you don’t fit manifold yourself. That’s quite a lot of petrol!! Hope this is of some help.
I had mine done at Williams in May - the cost was very similar to what you have said - £1350 for manifold and cat, and £332 for the ECU remap. I also paid £485 for the sports exhaust. The labour was £545, and then the VAT was £482! Total inc VAT was £2892.
That doesn't sound right. presumably the £332 for the remap is all labour anyway which leaves £545 for just fitting the manifold and exhaust? Surely it can't be more than a couple of hours work tops?
Hi - just looked back at this and checked the paperwork - the total labour was £545. ECU labour was £332.50, and the labour for the manifold/cat/exhaust etc was £212.50. All excluding VAT. Sorry I didn't make that clearer before!
