5 members (TalkMorgan, Tresco, KennethM, DaveW, Morganmike), 295 guests, and 93 robots.
Sagging Hood
Topics49,859
Posts837,483
#592352 28/08/19 04:46 PM
Ray Offline OP
Can anyone help. After checking my brake fluid today found a short loom hanging beside the reservoir with a plug in socket on the end . Don't know if I knocked it off a connection or it was there all the time. I can't find anywhere to plug it back in. Everything on the car electrical seems to work ok. Hopefully someone can help. The car is a 1800 duretec 4/4 .thanks in advance. PS one wire is black and green the other black.
Is it for a brake fluid level indicator in the reservoir and normally attached to the reservoir cap?
Ray from a quick check of BS wiring code i.d. it would seem from the colours you identified that the plug may be related to the fan relay..? Is there a relay within reach of the harness that the plug might have been connected to..?
http://www.dimebank.com/LucasColours.html
Ray Offline OP
. Can't find anything near it, the wires are only about nine inches long near the servo. Thanks for your thoughts.
Ray Offline OP
. i wonderd that but the reservoir has a form of rubber gromit in the top. Perhaps it's never been conected to anything. It is a Morgan. Thanks for your help.
Rog Offline
Spare washer motor connection should you ever need to move the steering wheel to the other side.
Roger
Ray Offline OP
who knows as I said it's confirmed now as a genuine Morgan.
Rog Offline
Take a look at the chassis harness drawing towards the bottom of the 2006 parts book. There is a washer connector on both sides of the car (wire colours LGB and B).
Roger
You can find wiring diagrams at http://www.gomog.com/allmorgan/44WiringDiagrams1998on.html
According to that the brake fluid level should be black and white. Black should be the earth (negative). I can't find any likely reference to black and green so given its location I think Max5 is correct and it is the brake fluid level switch.
I suspect that the cap should look something like this:
Don't worry it's like Rodger says.
Stefan
