6 members (Ruut Bianchi, nick w, Mark+4, Anonymouse, Moggo, High Hamster), 261 guests, and 40 robots.
+8Rich 101
John V6 59
Topics49,912
Posts838,159
Georgetoad, woolfie
#592528 29/08/19 06:12 PM
RBW Offline OP
So with a fortnight until I go to the factory, the foam at the top of my heater that is supposed to seal against the bonnet is falling apart.
As I would rather not coook myself on the journey, I took some measurements from the remaining good side and attempted to make a replacement out of some closed cell foam I had, but it looks rubbish.
I cant seem to find something that will do the job online, has anyone anyone come accross anywhere selling this?
I presume Morgan will sell me a length whilst I am there but I doubt it will be cheap.
Thanks in advance
2015 Yellow +4
RBW #592532 29/08/19 06:48 PM
I brought length through Amazon, did the job perfectly. However it was a denser foam than the one used st the factory.
Martin (Deano)
RBW #592533 29/08/19 06:59 PM
RBW Offline OP
Thanks for the reply Martin,
How do you find it seals against the bonnet?
2015 Yellow +4
deano #592546 29/08/19 09:33 PM
Do you recall the exact material you ordered?
thanks
Gary
RBW #592547 29/08/19 09:39 PM
Have a look in Woolies. They sell a range of materials.
I have used plasticine to measure gaps. Tease it to peaks and a closing bonnet will compress it .
https://www.woolies-trim.co.uk/
RBW #592549 29/08/19 09:47 PM
Since foam deteriorates over time would a neoprene seal of suitable cross section work? I had in mind something that included a hollow circular section that allowed plenty of crush distortion before sealing. Something like this sealing a cold air inlet shroud to the bonnet as its closed.
RBW #592584 30/08/19 08:05 AM
There was a previous thread on this a couple of weeks ago with some good photos, but I don't know how to post the 'link' to it
RBW #592591 30/08/19 09:38 AM
Scroll a long way down on this thread......
http://www.talkmorgan.com/ubbthreads.php/topics/375009/9
The seal is quite unsightly so I covered mine in leather. Around the bonnet hinge I added some neoprene. The combimation works very well.
On my 2005 the seal is a hollow panel edge type seal.
RBW #592593 30/08/19 10:00 AM
I can confirm that! The price that they charged me was eye-watering but I don't recall what is was, only that I was shocked.
RBW #592594 30/08/19 10:13 AM
I just went out and measured mine. It is cut out of 20mm neoprene sheet. You could try https://www.rhnuttall.co.uk/sheeting/neoprene-sheet/. They probably only sell in bulk but you could ask if they can sell you an off cut piece.
