4 members (paulmog, bilibib, RichardV6, Camelot), 288 guests, and 40 robots.
John V6 68
+8Rich 66
DaveW 64
9,208 Registered Users
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,346
Posts813,057
Captain Morgan, IRWIN
Originally Posted by nippymog
It is super simple as LightSpeed says, what fooled me is you have to take the bolt out to let the column slide up so you can rotate it to select another position.
Yes, it is keyed in a fashion like the ball detents on the quick release, but done with that clamp bolt.
AZ best check that you are getting the same amount of steering lock left & right. The wheel could be off if the track rod ends have not been equally adjusted when fitted.
Tim
Start the process with the wheels pointed straight ahead so you will have exactly the same rack position as before.
