Posts837,957
Posts: 60 |
Had been out for a cruise post dinner tonight and was teetering from 0-4% fuel on my ride home. Planned to stop on the way for gas but as I was coming to a stopsign I hit a pothole with the rear wheel and it died. Pushed her to the gas station (a block away at that point) and filled up a bit. Attempted to start a bunch of times, she even fired one rev, but it didn't start. We have gas in the tank, we have spark, something tells me this sounds vaguely like a fuel pump problem. Anyways, having no tools, and not knowing what relay to tap or swap with another, I gave up and called a flatbed and had it brought to where it sleeps. Car has 1200 miles and was just in 200 miles ago for service. Battery is good by the way.
All a little confusing since I don't know the car mechanically very well yet, but quite frankly funny to me. I can't wait to see what it is, fixing these kinds of things is always a learning process for the better.
Any ideas on what to start checking?
Posts: 415 |
From another thread, originally posted by Red Three
‘Behind the oil tank is the reset button for the impact/accident cut out. It's a black, rubber shrouded button and can occasionally disconnect for no good reason. Worth finding and giving it a press. Easiest thing to eliminate. Good luck finding the problem’.
This could be your problem, especially after hitting that pothole.
Posts: 60 |
Just looked this up in the manual after you posted it! You are right. They call it an inertia switch, section 14.3. I should have known to check for a fuel pump cutoff switch from my MGB days... :-)
Thank you kindly and I will let everyone know.
Posts: 60 |
Hi Guys, this was in fact my problem. I pressed the button to reset it and she fired right up. For anyone who hasn't dealt with this before, here is a picture of the switch so you can find it easily if this happens to you. https://imgur.com/G81Ojcf
Posts: 415 |
Thank you kindly and I will let everyone know. Happy to be of service Royal and that you are back on the road
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
Can't help but wonder how much misery this little switch has caused us M3W owners over the years.
Andy
Posts: 237 |
Piloting Saint Ex the Morgan
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
It's a rubber button right behind and just below the oil tank. It is not hidden away.
Posts: 60 |
