10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike), 273 guests, and 42 robots.
+8Rich 91
Luddite 50
Posts837,969
#593758 06/09/19 05:53 AM
Had been out for a cruise post dinner tonight and was teetering from 0-4% fuel on my ride home. Planned to stop on the way for gas but as I was coming to a stopsign I hit a pothole with the rear wheel and it died. Pushed her to the gas station (a block away at that point) and filled up a bit. Attempted to start a bunch of times, she even fired one rev, but it didn't start. We have gas in the tank, we have spark, something tells me this sounds vaguely like a fuel pump problem. Anyways, having no tools, and not knowing what relay to tap or swap with another, I gave up and called a flatbed and had it brought to where it sleeps. Car has 1200 miles and was just in 200 miles ago for service. Battery is good by the way.
All a little confusing since I don't know the car mechanically very well yet, but quite frankly funny to me. I can't wait to see what it is, fixing these kinds of things is always a learning process for the better.
Any ideas on what to start checking?
From another thread, originally posted by Red Three
‘Behind the oil tank is the reset button for the impact/accident cut out. It's a black, rubber shrouded button and can occasionally disconnect for no good reason. Worth finding and giving it a press. Easiest thing to eliminate.
Good luck finding the problem’.
This could be your problem, especially after hitting that pothole.
Just looked this up in the manual after you posted it! You are right. They call it an inertia switch, section 14.3. I should have known to check for a fuel pump cutoff switch from my MGB days... :-)
Thank you kindly and I will let everyone know.
Hi Guys, this was in fact my problem. I pressed the button to reset it and she fired right up. For anyone who hasn't dealt with this before, here is a picture of the switch so you can find it easily if this happens to you.
https://imgur.com/G81Ojcf
Happy to be of service Royal and that you are back on the road
thumbs
Can't help but wonder how much misery this little switch has caused us M3W owners over the years. irked
Andy
how do you access it ?
Piloting Saint Ex the Morgan
It's a rubber button right behind and just below the oil tank. It is not hidden away.
See my pic above, Osten.
