1 members (RedThree),
284
58
Topics49,844
Posts837,360
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
...is equipped with the necessary reverse gear electric contact to switch a reverse light. ... visually confirmed the switch is connected to wiring loom on my UK spec car. Am now mildly optimistic that a live reversing light connection will be available at the four wire rear light connector, since colour codes match from switch. ... Presumably one could also short the reversing wire to the fog light wire and get that to turn on with reverse? Might break a few regulations though, so perhaps fit a fuse to the short to enable it to be disconnected for MOTs etc... just a thought!
Posts: 8,664 Likes: 408
Posts: 8,664 Likes: 408 |
If my interpretation of the wiring loom diagram is correct the four cable connector to the existing rear fog light below the number plate, also carries the gearbox switched feed to the reversing light whether its fitted or not, so you can choose to have either. Each are fused independantly and have a dedicated return, hence four wires. I hope eventually to re-locate the rear fog light, but in the short term a reversing light is going to be far more useful.
Posts: 1,490 |
Where can I get a wiring diagram for the car?
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 2,539 |
Let me find my Find my link to the parts manual...
Posts: 2,539 |
Posts: 181 |
If you look at the 3W ex Aero Racing for sale on the Allon White website it has a reversing light fitted above the rear light, plus many other modifications.
If you look at the 3W ex Aero Racing for sale on the Allon White website it has a reversing light fitted above the rear light, plus many other modifications. Many thanks - I knew I had seen one with retro fit reversing light elsewhere.  Wonder where the pod was sourced. Seems a good match to MMC supplied originals.
Posts: 181 |
I think it's the same as the indicators etc with a clear lense
Posts: 902 |
I think it's the same as the indicators etc with a clear lense The indicators/rear lights/stop lights all look similar externally, apart from lens colour, but appear to be lower power than the rear fog and reversing lights which have a heat sink attached to the rear of their bodies behind the mounting points.
