7 members (Barkbark, Graham, G4FUJ, +8Rich, sewin, Themorganeer, Morganmike, TBM), 323 guests, and 114 robots.
+8Rich 79
DaveW 52
Topics49,866
Posts837,608
OhioM3W #595621 18/09/19 12:37 PM
O
OhioM3W Offline OP
O
Thanks everyone for your suggestions. Note that the clanking sounds only occurs when the engine is in gear. I have been taking it out of gear and avoiding downshifts to eliminate the sound. Makes me think it's not the belt.
OhioM3W #595628 18/09/19 01:24 PM
taking it out of gear and, in effect coasting, does not mean that it is not the belt. The belt "slaps" when there is reverse pull against it. being out of gear eliminates the reverse pull.
Think of it this way.... going forward at speed the top of the belt is pulling the wheel/sprocket. When you decelerate the wheel/sprocket is now pulling the engine through the bottom of the belt.
Rodger
2004 Plus 8 (wife's)
OhioM3W #595629 18/09/19 01:25 PM
What year is your car? Does it have the Centa compensator, or is it a pre 2014 car with the original Harley style compensator.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
OhioM3W #595894 20/09/19 08:11 AM
When my M3W came back from its re-manufacture at Malvern last year, I was amazed how tight the belt was. I was checking as they had not bothered to pump up the tyres, I wondered if they had tightened the belt properly. Like a rod of iron is how I would describe it, with maybe less than 1/4" of deflection possible. Considerably tighter than I would have made it before, anyway. My M3W has always clanked at low speed over a rough road both with original chassis' rigid mounted BB and now NVH bushed BB. I found it is quite sensitive on this to rear tyre pressure. Even slightly above 25 psi and the clanking increases a lot.
Wilson
Rog G #595973 20/09/19 05:50 PM
O
OhioM3W Offline OP
O
It's a 2017...
Wilson
I had same experience. When car came back from the factory last year after the chassis upgrade the belt was very tight. I released it to my normal tension. This year I also got a clonking sound from below. Checked everything where it could be come from. I tensioned the belt much tighter ( too tight to my opinion ) and the clonking sound was gone. But I feel a bit uncomfortable with such a tight belt.
I have no NVH installed.
www.m3w-jungfrau-treffen.com
OhioM3W #598066 04/10/19 07:48 AM
Laurens did you have a replacement chassis? My cracked 2013 one replace & it now has the NVH kit but not originally.
TimG #598154 04/10/19 08:23 PM
Still have the original chassis without NVH
OhioM3W #652065 22/07/20 09:58 PM
O
OhioM3W Offline OP
O
So it turns out that the clanking sounds was the belt rubbing up against the mudguard when downshifting. Not sure why depressing the clutch made it go away. Anyway, I considered tightening the belt but everything seemed fine so I ended up removing the mudguard, bending it a bit and bolting back on. No more issues.
OhioM3W #652084 23/07/20 01:06 AM
I cut a notch in the mudguard.
