1 members (Bitsobrits),
292
45
Topics49,844
Posts837,360
Posts: 378 |
Have an unusual problem - well the first time its ever happened on this car. None of the lights,indicators,brake lights or wipers work - any inspirational ideas? Have checked the fuses which are all ok and nothing has been worked,on etc since it worked fine last time. The engine starts and runs fine. thanks Taffy
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
Worn wire insulation..................somewhere Had it in my fusebox
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Posts: 378 |
do you mean that the outside of the cable has either worn away,etc to such an amount that it shorts out? I just cant understand why the fuse never went? Is there any method in trying to find the problem or just luck? where in the fusebox was your problem? sorry about all the questions but it seems a daunting task !! regards taffy
Yep, friction ruined the ouside plastic round the cable My dealer fixed it
i drove from lake district to Brussels without dashboardlights, indicators and...
Posts: 378 |
blimey - what a trek wthout all lights ! thanks for all your input taffy
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
blimey - what a trek wthout all lights ! thanks for all your input taffy I wouldn't worry he never uses them. The force is strong with this one. Taffy not sure how they are set up but have you checked the relays.
Slowly going green
Posts: 7,930 Likes: 132
Posts: 7,930 Likes: 132 |
Taffy, have you run the battery down?
A dead battery in the Aero can send the ECU into a frenzy.
Resetting the ECU clears this issue.
Posts: 378 |
hi Simon Actually waiting to get a new wheel meant the battery went flat and the car was jump started. Is resetting the ECU a job I can do or is it a factory/dealer job? regards Taffy
You can do it.
I'll try to explain it.
First, make sure your battery is charged - trickle charge for 24-hours is best
The car should be turned off, cars out of the ignition before doing the next steps.
Second, pop the bonnet on the drivers side (on a RHD) car; in front of the passenger compartment, you should see a large metal box. At the front of this box will be a black switch with a red push button.
Press the red push button and a small arm will pop out. This is resetting the ECU.
Leave the car for 5-minutes (do not push the arm back into the side)
After 5-mins, push the arm back into the side of the black switch.
Close the bonnet and start the car.
This will have reset the ECU and should resolve any lights, cabin fan, indicator issues.
I can take some photos if the above doesn't make sense.
Posts: 378 |
Thanks Simon, I will give it a go in the morning. Seems to be easier than finding a "short" in the wiring loom ! regards taffy
