0 members (),
254
42
Posts837,276
Posts: 6,954 Likes: 115
Posts: 6,954 Likes: 115 |
No, not wi-fi, wood routers. Does anyone know of a good jig to use for dovetails on a router table? Thanks all.
Thanks, Craig but it doesn't look as if it could be used on a router table. Do you have experience of using one? Thanks.
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
Thanks, Craig but it doesn't look as if it could be used on a router table. Do you have experience of using one? Thanks. No experience with the dovetail jigs sorry Bob, only by hand during my college days. How about this one https://www.axminster.co.uk/leigh-rtj-400-router-table-dovetail-jig-506731
Craig Jezz
Posts: 541 Likes: 7
Posts: 541 Likes: 7 |
Using a dovetail jig on a router table is not the easiest way to cut a dovetail joint as getting a good registration of the 2 pieces of wood that will make the joint is quite difficult.
A dovetail jig that that allows both pieces wood to be accurately aligned as the dovetail is cut is a much better way of doing it. There are a lot of jigs available but they can be quite pricey. The Trend and Incra jig are good examples.
If you want to use one on a router table then the Leigh jig has a good reputation but I have not used one.
Posts: 808 Likes: 29
Posts: 808 Likes: 29 |
I bought this at a wood working show after watching a Demonstration, but have not used it yet. Too many other gardening jobs to do around the house before doing more wood work.
However it seemed pretty impressive at the demonstration.
Thank you all for your suggestions. I'll look into them. Chris - Which one are you talking about? Cheers.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Just installed a new router at home. I now get 50 Mbps download and 11 Mbps upload
