3 members (Craig Jezz, Beard, sprinty), 385 guests, and 29 robots.
+8Rich 92
Topics49,839
Posts837,301
#596957 26/09/19 09:09 PM
No, not wi-fi, wood routers. Does anyone know of a good jig to use for dovetails on a router table? Thanks all.
Best Regards
Lang may yer lum reek
BobtheTrain #596959 26/09/19 09:24 PM
https://www.amazon.co.uk/Trend-CDJ3...;qid=1569532905&s=gateway&sr=8-5
Craig Jezz
Craig Jezz #596960 26/09/19 09:28 PM
Thanks, Craig but it doesn't look as if it could be used on a router table. Do you have experience of using one? Thanks.
Best Regards
BobtheTrain #596961 26/09/19 09:37 PM
No experience with the dovetail jigs sorry Bob, only by hand during my college days.
How about this one
https://www.axminster.co.uk/leigh-rtj-400-router-table-dovetail-jig-506731
Craig Jezz
BobtheTrain #596962 26/09/19 09:42 PM
Using a dovetail jig on a router table is not the easiest way to cut a dovetail joint as getting a good registration of the 2 pieces of wood that will make the joint is quite difficult.
A dovetail jig that that allows both pieces wood to be accurately aligned as the dovetail is cut is a much better way of doing it. There are a lot of jigs available but they can be quite pricey. The Trend and Incra jig are good examples.
If you want to use one on a router table then the Leigh jig has a good reputation but I have not used one.
BobtheTrain #596967 26/09/19 10:01 PM
Used to use this in work, nightmare to set up but once sorted it did work very well
https://www.screwfix.com/p/trend-30...SmL7v5AIVR9TeCh23DwgCEAQYASABEgIMxvD_BwE
BobtheTrain #596968 26/09/19 10:15 PM
I bought this at a wood working show after watching a Demonstration, but have not used it yet. Too many other gardening jobs to do around the house before doing more wood work.
However it seemed pretty impressive at the demonstration.
BobtheTrain #596971 26/09/19 11:21 PM
Thank you all for your suggestions. I'll look into them. Chris - Which one are you talking about? Cheers.
Best Regards
BobtheTrain #596985 27/09/19 07:36 AM
Just installed a new router at home. I now get 50 Mbps download and 11 Mbps upload smile
BobtheTrain #597012 27/09/19 09:31 AM
Sorry I thought I had cut and paste the link.
https://gifkins.com.au/shop/finger-joint-masters/
