Morgan Aero 8
6 members (Pittsartist, RichardV6, sbarracl, The Austrian, Ian Wegg, Saxman1964), 347 guests, and 36 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,343
Christoph
#59643 15/04/11 04:56 PM
taffy Offline OP
Have an unusual problem - well the first time its ever happened on this car. None of the lights,indicators,brake lights or wipers work - any inspirational ideas? Have checked the fuses which are all ok and nothing has been worked,on etc since it worked fine last time. The engine starts and runs fine.
thanks
Taffy
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Goodwood Drifter
Goodwood Drifter
Worn wire insulation..................somewhere
Had it in my fusebox
Steven
now: +fourLM62
taffy Offline OP
do you mean that the outside of the cable has either worn away,etc to such an amount that it shorts out? I just cant understand why the fuse never went? Is there any method in trying to find the problem or just luck? where in the fusebox was your problem?
sorry about all the questions but it seems a daunting task !!
regards
taffy
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Goodwood Drifter
Goodwood Drifter
Yep, friction ruined the ouside plastic round the cable
My dealer fixed it
i drove from lake district to Brussels without dashboardlights, indicators and...
Steven
now: +fourLM62
taffy Offline OP
blimey - what a trek wthout all lights !
thanks for all your input
taffy
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
le Asbo du Bling
le Asbo du Bling
taffy
I wouldn't worry he never uses them.
The force is strong with this one.
Taffy not sure how they are set up but have you checked the relays.
Slowly going green
Taffy, have you run the battery down?
A dead battery in the Aero can send the ECU into a frenzy.
Resetting the ECU clears this issue.
taffy Offline OP
hi Simon
Actually waiting to get a new wheel meant the battery went flat and the car was jump started. Is resetting the ECU a job I can do or is it a factory/dealer job?
regards
Taffy
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
You can do it.
I'll try to explain it.
First, make sure your battery is charged - trickle charge for 24-hours is best
The car should be turned off, cars out of the ignition before doing the next steps.
Second, pop the bonnet on the drivers side (on a RHD) car; in front of the passenger compartment, you should see a large metal box. At the front of this box will be a black switch with a red push button.
Press the red push button and a small arm will pop out. This is resetting the ECU.
Leave the car for 5-minutes (do not push the arm back into the side)
After 5-mins, push the arm back into the side of the black switch.
Close the bonnet and start the car.
This will have reset the ECU and should resolve any lights, cabin fan, indicator issues.
I can take some photos if the above doesn't make sense.
taffy Offline OP
Thanks Simon, I will give it a go in the morning. Seems to be easier than finding a "short" in the wiring loom !
regards
taffy
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
