Topics49,886
Posts837,858
Posts: 44 |
How do I make my mohair hood water-proof?? It is in excellent condition; it leaks in rain at points where hood sits on hood framework...and I do mean leaks.
Any suggested remedies welcome
Posts: 5,587 |
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Ray, The seams and the general hood fabric can be reproofed with Fabsil. I use it and it works for me. If however, you are concerned about leaks around the screen, Dave W and others will be along shortly.
Posts: 27,827 Likes: 754
Posts: 27,827 Likes: 754 |
Wax the seams with dubbin. There are also fabric sealers you can get . Autoglym sell one
This is MMCs latest on the header rail from a Roadster demo I borrowed last week. Please note the header leaked & mine doesn't but that might have been the set up. The hooder rail wouldn't release at the back so the hood alignment & tightness to the top rail couldn't be adjusted easily. They have fitted some foam to seal the gap by the A pillar. I will copy that as on mine it let in draughts. ![[Linked Image]](https://www.tm-img.com/images/2019/09/29/20190924_163735.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/09/29/20190924_163743.jpg) They added this ribbed strip of rubber inside the seal but you can see it partly fouls the U shaped cut to allow for the sun visor mounting arms ![[Linked Image]](https://www.tm-img.com/images/2019/09/29/20190925_124913.jpg)
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Renovo is another hood proofer.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Renovo is another hood proofer. I used Renovo on my previous Mog and it seemed to work a treat
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
Agree with all the above solutions but try rubbing some candle wax into the seams where they contact the hood rails etc. Should be ok then.....
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 809 Likes: 30
Posts: 809 Likes: 30 |
