2 members (+8Rich, ScotiaSteve),
314
101
Topics49,860
Posts837,484
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
looks like a good option for my ruined signal. I am surprised that that one is not listed at JP cycles.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Those lamps look good but will the guts take the heat? Only time will tell, so please keep us Posted for I would wager that there are others who will experience the meltdown.
mine melted down as one of the bolts backed partially out and the signal rested on the pipe ![[Linked Image]](https://i199.photobucket.com/albums/aa88/rcmatt007/drg1_zpsqxjveuun.jpg)
Posts: 557 |
Arlen Ness turn signals have been mounted for almost a year and survived a couple of 110F days 🤙
Arlen Ness turn signals have been mounted for almost a year and survived a couple of 110F days 🤙 That is good to know. And Rodger, that is some meltdown! Loose bolt allowed it to rest on the pipe, so it might pay to use some high temp loctite on the bolts.
it was my bad. it is very hard to see up where the nut was. I used the stock top bolts from the US fitment and changed over to the UK brackets. The stock bolt was a wee bit short and did not engage the plastic of the lock nut. Only when I but a new nut at Lowes and contorted myself in the parking lot fixing it, that I could see the problem. Unfortunately to fit a longer bolt I will need a lift to take the pressure off the top steering strut. Not something I could do 200 miles from home
These little beasties seem to need a lift for darn near everything. I hope the replacement stays put.
Did the other turn signals continue to work?
yes, everything continued to work, so no blown circuits
yes, everything continued to work, so no blown circuits 👍 amazing!
well, except the front right!
