5 members (Saxonian, Clipper, John Winn, BobtheTrain, Vansrv6), 196 guests, and 93 robots.
+8Rich 62
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,762
#597624 01/10/19 12:43 PM
MOG 615 Offline OP
I am installing a manual overide to the engine fan actuation system that is currently only triggered by the otter switch in the radiator.
I plan to piggyback connectors from the otter switch to a manual switch on the dashboard
In order to keep the dash looking tidy I was proposing to use the redundant variable instrument lighting rheostat. Obviously that in itself is not suitable, so I was planning to utilise an on/off matching switch (much like the heater fan switch) and replace it. I know I could use almost any type of switch if I was to install it under the dashboard out of sight, but i would rather keep it on view if possible, and if it had a fan icon that would illuminate when in use that would be ideal.
Does anyone know what these switches were sourced from originally? I have been trying to find something, and each time I keep hitting a blank wall.
Many thanks for help in advance.
Andy G
1999 +8 , Indigo Blue.
Try Holden.
MOG 615 Offline OP
Originally Posted by John V6
Try Holden.
Thanks John , will do .
Andy G
I wonder if this one would fit in. Illu fan rocker
MOG 615 Offline OP
Try Holden.
They have this 2-speed fan switch but have no idea if it will fit , so I have to do some measurement and check it.
https://www.holden.co.uk/p/heater_fan_2_speed_rocker_switch_off_on_o1
Andy G
