Morgan Aero 8
10 members (Steve3.9+8, Jon G4LJW, nickmog99, davewhite, Tom Sayles, JMcL, jbk, Hamwich, CRL, MATTMOG), 217 guests, and 120 robots.
+8Rich 78
Topics49,872
Posts837,687
Rudolf
We had a friend with an Aero arrive here a couple of years back and it turned out that a seemingly good battery was going flat overnight however if he operated the inertia kill switch, thereby disconnecting the battery, it would start without problems the next morning. We went to the local auto electrician and discovered two things: 1) there was a constant drain on the battery that was enough to flatten any battery overnight, and 2) the battery was a little down on power and needed replacing.
It was too difficult to identify the source of the drain but when the battery was replaced the current drain dropped back to virtually normal for the various small items that had to remain live to some degree, central locking, radio, etc.
So it seems that if the battery is not fully up to the correct voltage some item in the car was not fully disconnecting when the ignition was turn off. With a fully charged battery the item turned off correctly. confused2 confused2 confused2
This friend it was me .... Chanteclair
I wouldn't hold too much store (pun?) by measured off load voltages after charging or discharging Peter. Both situations take place at the battery plate to electrolyte interface, but the electrical storage of a lead/acid battery is chemically within the depth of the plates so it takes a while for the measured voltage to stabilise after either condition. See table below for a guide to battery condition, only relevant after resting for several hours from use.
Please note that specific gravity of the batteries electrolyte is a better guide to battery condition rather than off load voltage. This is measured with a hydrometer but only if you have access, i.e. no help with a sealed battery. Even then it gives no indication of the batteries capacity which can only be assumed as advertised when new or nearly so. Part of the ageing process is sulphation where the lead sulphate on the plates of a discharged battery can crystallise, effectively reducing their surface area in contact with electrolyte. This situation is greatly accelerated if battery is left unused in discharged state, hence importance of battery charger on float/maintenance mode when vehicle out of use for several weeks.
A sulphated battery will have a much diminished capacity, hence will charge and discharge quickly. It may show the full 12.7 volts indicating it's fully charged but only within the constraints of its limited capacity which even then may not be enough to turn engine over long enough for it to fire, especially mid winter, and hence my initial comments. The "repair" mode on your charger will be an attempt to reverse the sulphation by deliberately raising the charge voltage and often called equalisation. You usually get a warning in the chargers instructions not to have anything connected during operation in this mode since a 12 volt battery can hit up to 16 volts during such charging.
A lead/acid battery even left without load will still loose approx 5% of its capacity/month due to internal discharge. Having said all this I would be very dissapointed if a normally regularly used battery, in a new or old car, wouldn't start the vehicle after at least three weeks, in an airport car park for example.
Originally Posted by Peter J
We are back from a weekend away, having driven the car about 200 miles. The battery us showing 12.9v, ignition off.
I've connected the charger, a "RING" brand device that charges, maintains, repairs and keeps a battery warm in very cold conditions. It is capable of charging at 12A in repair mode.
In maintenance mode it sarges at up to 0.5A.
The battery is new, a Yusa 60Amp device.
There is no tracker or other device and the USB adaptor is unplugged.
When the ignition is off the heated front screen with is partly illuminated for about 10 min before going out.
Also, as soon as the door is opened the footwell lights come on and the seatbelt, hazard flasher and heated screen come on.
The Radio is an Alpine device that does not have any ability to retain station information when disconnected.
Its highly unlikely that there is a battery fault. 12.2 v is a battery roughly half charged so you are saying that the car when switched off uses 30aH in 10 days or a constant drain of 125 ma. Without a radio or tracker and alarm / immobiliser (does it have one?) there should be no drain at all, or to be totally correct just the small internal drain that every lead acid battery has.
Finding what is happening is a tiresome ballsaching exercise involving putting an ammeter on the battery lead whilst in the garage , noting the current flow and then disconnecting various bits of the electrical circuit to see what changes. Personally I couldnt be bothered. I'd simply wire in a trickle charger and plug the car in every few days. For travel abrioad you can get solar chargers that put out that level of power.
The Morgan has lots of quirks - this is just another!
P.S. If you do decide to have a go, I would start with the items you have highlighted. The hazards shouldnt come on when you open a door and neither should the heated screen
I generally turn the electrics off using the master switch then have the battery on a Ctek attached to a timer which runs for about two hours a day.
The Speedster has a tracker - which I am required to have by all the insurance companies I contacted- has the usual floor-well lighting on shut down, an Alpine head unit - but other than that-not particularly problematic or unusual .
In the time I've owned - always started first time. Hope it stays that way.
Bulb warning - is , however, a " feature" when no bulb appears to have failed- and its intermittent. I just ignore it.
I have random lighting of the warning switches and the dials. Sometimes all - sometimes - just some. I just ignore it.
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
Smile, it confuses them
I work on the EE Lightning/SR71 principle.
If at least one of the dashboards lights is not on when it is at rest locked in the garage then this indicates the battery is flat or close to.
JB62 #600531 23/10/19 07:11 AM
Peter J Offline OP
Formerly known as Aldermog
As Howard has said, a Morgan has lots of Quirks!
JB62 #600950 25/10/19 03:24 PM
I solved this one by switching on the headlights after switching on the car.
Mine can anyhow stay 2/3 weeks without the CTEK connected, but I fear the moment when I want to use the car and it does not start, so recently I got the habit to always connect it. Before via the cigarette lighter plug in the glovebox, now I decided to connect it directly to the battery, in this way:
Much better way of connecting charger thumbs
My Ctek clone charger came with an optional extra charge lead. It allows permanent hook up to battery, terminating in non reversible high current plug to match chargers, just as yours appears to have.
Has the Plus 6 arrived yet smile
S5 would probably fail to start after 5 or 6 days so keep it on charge 3 days +
No point worrying about it - just a Morgan thing.
Plus fours have always been okay for 2 weeks plus.
2016 Carmine Red 991.2 C4S
