1 members (Montegue),
367
47
Posts837,277
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
![[Linked Image]](https://i.imgur.com/kRNQeta.jpg) My heater's starting to look a bit secondhand.
1972 4/4 2 Seater
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Some useful stuff here on rebuilding them; similar to the one in my S2a Land Rover.
Posts: 5,432 Likes: 466
Posts: 5,432 Likes: 466 |
Great info Richard. I have enjoyed a measure of success by attaching a garden hose to both heaters and Radiators and flushing their cores, by sending the pressurised water through in one direction then reversing the direction and repeating that process until the discolouration of the water flowing out of the cores cleans up... This can be done with the heater/rad left fitted in the car...
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
I've rebuilt a couple of these Smith's heaters.
My starting point has always been a new core from Holdens (made by Claytons)as I've never come across one which doesn't leak and given the age of them they tend to be pretty crispy by now.
The biggest problem I faced was the pivots for the flaps which sheared off. Removing the remains was a bit tricky and so I used some stainless wire to make new ones.
I delicately bead blasted the casings and then used VHT crackle black paint to finish it.
Arwyn
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Way back we cleared out an old BL dealership which had gone bust, and there was a boxfull of those circular matrices...……..I wish I'd kept them......along with a lot of other stuff, which filled a transit box van.
Arwyn That's almost exactly what I've done. The core's on order from Holden's and I'm going to replace the sheared hinges on the flaps with brass panel pins.
1972 4/4 2 Seater
![[Linked Image]](https://i.imgur.com/UR97xUa.jpg) The new element's almost too nice to put on the car.
1972 4/4 2 Seater
