Posts837,951
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
could always go with this.... https://www.amazon.com/Indian-Motorcycle-Chrome-Headdress-2883668-156/dp/B07J1ZV16D/ref=asc_df_B07J1ZV16D/?tag=hyprod-20&linkCode=df0&hvadid=366403762001&hvpos=1o4&hvnetw=g&hvrand=10420347038339622634&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008718&hvtargid=aud-829758849484:pla-813054122385&psc=1&tag=&ref=&adgrpid=83058288864&hvpone=&hvptwo=&hvadid=366403762001&hvpos=1o4&hvnetw=g&hvrand=10420347038339622634&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008718&hvtargid=aud-829758849484:pla-813054122385
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
My most recent, and last, edition to lighting of my M3W. Now in dim lighting conditions cars alongside me or close to me will know I want to turn. Having only the turn indicators only visible from directly in front of me just didn’t seem right. http://youtu.be/6Se7WDQE-1g
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Very nice, and practical to boot.
Steve Late 2012 M3W
Thank you Steve. I am surprised Morgan does not offer such a thing.
Posts: 960 Likes: 21
Posts: 960 Likes: 21 |
Excellent installation Stephen! In fact, I'm thinking that a small red light in the back of the mudguards should be considered! Or at least put a reflector. I'm concerned that anyone passing you, at night, doesn't realize how large the M3W really is, as the front wheels, with the black covers, are not so easy to "see"; and the tail lights might suggest you're as narrow as a motorcycle  I guess, Stephen, that your M3W is much more visible than others. Safer then. Excellent job. But don't go much further! Or it will look like a Guatemalan bus (love those, buy the way, but their lights are too much confusing at night!  . I hate driving close to them as you never know what they'll do!). No offense please  I'm sorry but couldn't resist… https://www.youtube.com/watch?v=or_T-KNDjtQBest regards
Thanks Javier, it is the last light to add.
As to lamps low on the tear of the fenders a reflector or reflective tape might do.
The Guatemalan buses are pretty amazing. They have come a long way from the dangling bells and tapestry inactive ornamentation.
Posts: 902 |
A job well done. How did you route the wiring?
Thanks John.
I ran the wires under the fender to the center down tube fender support. I drilled a small hole in the top of the down tube, deburred the hole and ran the wire down inside it. I sealed the top of the tube/hole so the wire would not wiggle and chaff and also seal off the hole from water and dirt getting into it. Then I slid armor flex plastic sheathing, the same stuff Morgan uses, up the pipe from the exit. I made a generous bend at the bottom of the loop and took the cable up to the top of the A-Arm and across to the pivot and made the connection there since it was the least amount of movement for the wiring.
It all works fine but I intend on adding a quick disconnect, waterproof, for removal of the fender to change wheel/tires.
Photos coming soon.
