8 members (+8Rich, John V6, Ian Wegg, TBM, MartinB60, RedThree, simon8201, James B W),
251
60
Posts837,958
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
I want to change the ribbed alternator drive belt on my 1600 Sigma because it sounds like an aviary full of canaries on starting from cold and particles of the existing belt can be found stuck to the underside of the bonnet. Has anyone done this and, if so, how is the belt tensioned?
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
There is a spring loaded tensioner built into the idler pulley. Step 1 = work out the routing Step 2 = Using a socket, slacken the tensioner Step 3 = Remove old belt keeping the routing in mind. Step 4 = Fit new belt Step 5 = Release tensioner Step 6 = Sit back and admire your work
Takes less than 2 minutes = if you can find the right socket.
Somewhere on TM IIRC there are pictures but once you try the idler with a socket it all becomes very clear.
New belt is Gates 6PK1203
Here is the original thread Here
Thanks Paul. Best wishes, Don.
Posts: 5,587 |
I want to change the ribbed alternator drive belt on my 1600 Sigma because it sounds like an aviary full of canaries on starting from cold and particles of the existing belt can be found stuck to the underside of the bonnet. Has anyone done this and, if so, how is the belt tensioned? Excellent description that , have heared those caneries a few times under the bonnet !
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
I want to change the ribbed alternator drive belt on my 1600 Sigma because it sounds like an aviary full of canaries on starting from cold and particles of the existing belt can be found stuck to the underside of the bonnet. Has anyone done this and, if so, how is the belt tensioned? How many miles have you done? You should not have particles of rubber stuck to the underside of the bonnet. I would investigate to see if something is out of alignment or possibly a damaged pulley before replacing the belt.
Bob
They do start slipping once they exceed their useful life. Ours made an awful racket - lasted 5 years and 24,000 miles.
Bob - 2015 car which has done 10500 miles (in my defence 6000 of those miles have been added since buying the car in April!) The belt particles are in the form of dust.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
I'll visually inspect the V-belt. After 75.000 km there are no complaints. Next year I wanted to change the timing belt and then the V-belt too. But 10,000 miles is actually far too short a lifetime for a V-belt.
I agree with you Heinz,
That, why I suggested checking for misalignment or pulley damage before replacement.
Bob
