9 members (dakri, JohnHarris, IcePack, lez, JoeSpeetjens, MartinB60, HJP, Plus Four Guy, TBM), 310 guests, and 29 robots.
+8Rich 91
Luddite 50
Posts837,974
Page 3 of 3 1 2 3
Originally Posted by Button
I just took a Stanley Knife and cut off one rib of a 7 rib belt.
Do you have a god complex?
Not unless his Morgan's name is Eve.
laugh2
Nice one! thumbs
Max5 Offline OP
After drawing a blank at several Morgan dealers my local motor factors had a belt in stock. Until talking to the factors I wasn't aware that all belt manufacturers use the same system of coding (6PK = 6 Peaks, 1203 = the length in mm). I could not find any reference to the 6PK 1203 on Gates website and the factors suggested that it may have been discontinued and replaced by 6PK 1200. The belt Morgan had fitted as O/E was 6PK 1195 so there is clearly some flexibility(!) in the length of the belt you can use - a benefit of the spring loaded tensioner? As previously stated, fitting was simple with a 5/8 socket on the tensioner (more in keeping with a Morgan than this funny foreign mm stuff!).
I was a buyer in a factory, engineering parts were the main items. We dealt with companies supplying belts, bearings, chains etc. Belts were standardised re sizes/configuration. Bearings by dimension (and type re taper/ linear/ standard).These companies also supplied motor factors. It was a cutthroat business with keen competition.
If you struggle with finding parts it may be worth googling some and chatting to them.
Some were national companies and others more local and might do a sale direct to you or give details so you can order via a motor factor.
Really hope you checked condition of bearings on each pulley by giving them a spin and wiggle whilst old belt was off as I think it highly unusual that a belt would start to fail so very early in its life. (As others have also mooted)
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Page 3 of 3 1 2 3
