7 members (bmgermany, Lance, cerealsurfer, Graham, G4FUJ, TBM, JMcL, M3WMW),
211
Topics49,909
Posts838,126
Posts: 378 |
I wonder if anybody else has the same issue - the exhaust on my SS (left hand side) has yesterday started to sound like a bolt has come adrift in it and really rattles badly. The exhaust itself - rear exit- feels really "solid" so it seems an "internal" issue. Any thoughts ? regards T
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 519 Likes: 60
Posts: 519 Likes: 60 |
I had a similar problem years ago and it turned out to be a loose baffle in the main exhaust box, if you press the box you can stop the rattle, what I did was cut an opening in the box and welded the baffle plate to the box and then welded the flap back. I suppose nowadays people will just buy a new exhaust box.
David Byrne
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
I I suppose nowadays people will just buy a new exhaust box.
David Byrne Not if they're from Yorkshire eh, David
Posts: 542 Likes: 7
Posts: 542 Likes: 7 |
Might be internal bits of the Catalytic Convertor rattling about, happened to mine on a Plus 4 and it sounded like a tin can with a marble in it.
Posts: 378 |
Thanks for the responses - I assume I cant do any damage in driving it 50 miles to the dealers? T
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
If nothing is rubbing, falling off or likely to snag then I cannot see it getting a lot worse. You could always give a local quickfit place £20 to slide it up on a ramp and have a quick inspection for risk mitigation then go to the dealer. They might even be able to tell you if they think it is in the box etc to help. Despite the mud often slung there is a usually a more trained one among them who is happy to lend a hand.
