Morgan Aero 8
6 members (Paul F, Rastus, andymog1, ChrisConvertible, Image, Simon), 227 guests, and 38 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,121
#603105 11/11/19 09:26 AM
taffy Offline OP
I wonder if anybody else has the same issue - the exhaust on my SS (left hand side) has yesterday started to sound like a bolt has come adrift in it and really rattles badly. The exhaust itself - rear exit- feels really "solid" so it seems an "internal" issue. Any thoughts ?
regards
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
taffy #603109 11/11/19 10:06 AM
I had a similar problem years ago and it turned out to be a loose baffle in the main exhaust box, if you press the box you can stop the rattle, what I did was cut an opening in the box and welded the baffle plate to the box and then welded the flap back.
I suppose nowadays people will just buy a new exhaust box.
David Byrne
B3MOG #603161 11/11/19 04:44 PM
Originally Posted by B3MOG
I I suppose nowadays people will just buy a new exhaust box.
David Byrne
Not if they're from Yorkshire eh, David
taffy #603239 12/11/19 10:07 AM
Might be internal bits of the Catalytic Convertor rattling about, happened to mine on a Plus 4 and it sounded like a tin can with a marble in it.
taffy #603262 12/11/19 01:56 PM
taffy Offline OP
Thanks for the responses - I assume I cant do any damage in driving it 50 miles to the dealers?
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
taffy #603278 12/11/19 03:51 PM
Smile, it confuses them
If nothing is rubbing, falling off or likely to snag then I cannot see it getting a lot worse. You could always give a local quickfit place £20 to slide it up on a ramp and have a quick inspection for risk mitigation then go to the dealer. They might even be able to tell you if they think it is in the box etc to help. Despite the mud often slung there is a usually a more trained one among them who is happy to lend a hand.
