Topics49,844
Posts837,355
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
But the delphi is ok I ll send the walbro for expertise at walbro Factory
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
But the delphi is ok I ll send the walbro for expertise at walbro Factory Any chance you have the leads from the Walbro to the top of the fuel pump housing the wrong way round? If the pump is running backwards it might be an issue.
Red Leader
With the walbro We try it outside in A fuel tank it was ok We try it on board with Only the Line to the engine it was ok We try it on board with the complete Line except the fuel filter ok we try it with the filter And fusible was out We ve done the same with A new fuel filter And fusible was out We try it on board complete fuel line and fusible 20 ampère the wire heat a lot Wait and see walbro expertise
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
![[Linked Image]](https://www.tm-img.com/images/2019/11/24/P1100436.jpg)
Andy
Posts: 2,539 |
New walbro arrived Dont Forget to change fuel filter .
