2 members (sprinty, TBM),
279
38
Posts837,992
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
I recently got a MOT advisory for loose spokes.
The nearside wheel is fine but on the offside about 1/3 of the spokes were slightly loose. It only needed 1/4 to 1/2 turn of the nipples to take out the slack but does anyone have an idea of what may have caused this?
And do I need to get the wheel refurbished/replaced?
Red Leader
Posts: 415 |
Chris, I’d give MWS a call and see what they have to say ....
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Spokes can loosen over time, the problem is if there are a lot the wheel may be out of true when you retighten them in the incorrect sequence. Not that I know what the correct sequence is. Jack the car up a and with a rudimentary pointer close to the rim spin the wheel to see if it is running out and by how much.
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Now that is a really good and simple idea, well done I will try that just to see what's what.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
"In the Old days" we checked them all the time on motorcycles.... that and greased the chain and put water in the battery... and checked the oil....
But with the offset of the wheel I am not shocked they can loosen. RogG is right.. check to make sure the wheel is true
Thanks all,
The loose spokes were all from the outside of the wheel and only required a slight tweak to tighten them up.
I will do Roger's check but the wheel seems fine and is in balance so I think it's just something to keep an eye on for now.
Red Leader
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
Rog G's suggestion does work, but remember to not only check left / right run-out but also that the rim has not pulled slightly oval in it's radius / rotation
Posts: 27 |
Also remember that some wheels have the hub laced in at an offset instead centered in the rim. The one I ran into was offset a quarter inch to align the rotor and caliper .
