4 members (piquet, GrumpyPa, JMcL, DavidR), 288 guests, and 57 robots.
Luddite 50
Posts837,951
Page 3 of 3 1 2 3
Originally Posted by Paul F
Originally Posted by Stewart S
There are special bonding pads that are available for the job which the adhesive is loosened by heat
These flex too much for use in a Morgan with the small pad that is fixed to the screen. The first one lasted less than 300 miles. The second one about the same. The flex is such that on a motorway, the image moves around so much that it is e=very distracting. I tried two different brands too.
Never had an issue with mine for some reason
I had the mirror stuck on to my last Mog and it lasted 3 years and 12,000 miles before I took it off using a jet lighter to heat up the metal bit when I changed to a folding windscreen
I remember seeing somewhere (maybe here) where someone replaced the blocks with small stainless steel knobs secured from the outside with countersunk allen headed bolts . I like this idea and if mine ever fall off, I will replace them with guitar strap knobs.
Kevin
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
The Plus Six has some rather delightful round Perspex knobs.
Agreed, when I asked the factory why they had changed it's because the current square ones won't pass the latest occupant safety test
I like that Jon !!!
My drivers side block flew out into my lap on a fast right hand turn in my 4/4..
Definite health and safety issue..ha ha
Page 3 of 3 1 2 3
