6 members (bmgermany, Grumpy2, Mkiss, Mats, Burgundymog, MJF), 205 guests, and 69 robots.
+8Rich 76
Topics49,863
Posts837,548
#606633 06/12/19 11:25 AM
O
Old man Offline OP
O
Hi all further to my earlier post we have 3 BCU that seam faulty 2 from an AR and 1 from a 2017 +4 .
The symptoms are as follows.
1st AR intermittent rev counter fuel gauge.
2nd AR new fitted side lights on all the time with the key out and the lights switched off.
1st AR refitted the same sidelight problem.
2017 +4 2amp fuse5 removed to check supply was replaced and now has sidelight as on AR controls.
Questions
1 Is there a reset system?
2 Is there a startup system eg power ignition on fuses in order.
In all 3 box,s the 2 blue LED ,s come on at power connection.
Any thoughts would be appreciated
Try disconnecting the main battery feed for say 30mins & make sure it's well charged to proper 'full' voltage then re-connect, simple but worth a try
