1 members (Ian B),
327
109
Topics49,867
Posts837,614
Posts: 62 |
Can you not just remove the hub from the wheel and get it balanced, I think that is what most do
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
I have a static balancer that I used to use when I raced bikes. Does a good job and yes it does make a difference having tried an unbalanced tyre.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I have replaced several worn back tyres on my M3W and never had them balanced, it's not been a problem. You can buy a bubble type balancer kit and some stick on weights from eBay for about £60. They work well for the front wheels as well if you cannot find a tyre fitter with the correct cones for wire wheels to fit a dynamic balancer
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
http://smoothridecones.co.uk/, get your prefered tyre fitter to buy a set, or get one yourself
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
+1 for Dynabeads, they work a treat.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
+1 for Dynabeads, they work a treat. But presumably if you use them in the rear tyre you can't also use Punctureseal or similar? I wouldn't run my rear tyre without some form of puncture sealant given the seriousness of a rear wheel puncture on the M3W.
Red Leader
Posts: 1,947 |
The balance weights on my rear wheel fell off when the paint peeled. If I had not found them on the garage floor I would likely never have noticed
Posts: 263 Likes: 2
Posts: 263 Likes: 2 |
+1 for Dynabeads, they work a treat. But presumably if you use them in the rear tyre you can't also use Punctureseal or similar? I wouldn't run my rear tyre without some form of puncture sealant given the seriousness of a rear wheel puncture on the M3W. [quote=Dab of oppo]+1 for Dynabeads, they work a treat. But presumably if you use them in the rear tyre you can't also use Punctureseal or similar? I wouldn't run my rear tyre without some form of puncture sealant given the seriousness of a rear wheel puncture on the Now that is a very good point!
2021 Morgan Plus Four 2012 Morgan Three Wheeler 2020 Land Rover Defender 110
Sorry, not enough clarification.
Dynabeads in the front and puncture seal in the rear. My local tyre fitter had no problem dynamically balancing the rear rim. It fitted on his machine without a problem.
Posts: 263 Likes: 2
Yep agreed. I have Dynabeads in the front tyres and they are very effective and have the puncture seal in the rear. I forgot myself when suggesting using the beads in the rear. They would work but the puncture seal is far more important
