8 members (Trim, nick w, Graham, G4FUJ, lord-richfield, ADMOG, Topline123, John07, mph),
284
41
Topics48,364
Posts813,342
Members9,215
Posts: 26,760 Likes: 425
Posts: 26,760 Likes: 425 |
Thank Rob. I think Santa might help me out shopping there my LEDs are quite old.
Posts: 7,941 Likes: 218
Posts: 7,941 Likes: 218 |
Quite impressed by the relatively new COB (chip on board) LED technology. Here a myriad of tiny basic LED chips are molded and connected into a single unit to provide a uniform solid block of concentrated light. No more of the slightly ugly individual elements that provide that patterned light. Just bought a rechargeable inspection light using such.
I have a gut feeling they may consume a little more power per lumen of light, but given meagre power consumption of LED's in general this would be a small price to pay for much improved light.
If I was upgrading lights on my car I would be tempted to wait until the dedicated format COB LED's become available.
Posts: 11,868 Likes: 138
Posts: 11,868 Likes: 138 |
Already available for exisitng bulb holder configurations: https://www.bettercarlighting.co.uk/index.php?searchStr=COB&act=viewCat&Submit=Go
Thanks Tim, bookmarked that page  ETA: beware, some shown are for 50/60's era positive earth cars!
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
........ the idiots that drive around in clear conditions with their rear Fog Lamps on are a real pain so hopefully these won't be too bright. Isn't that actual against regulation. On some cars it makes it less likely that a brake light will be observed. I find the idiots that constantly have the front fog lights on annoying too. I am not sure how it is now but certainly a few years ago there was no obligation to control the "aim" of fog lights for an MOT or similar inspection so sometimes they are aimed way too high.
Does anyone know if they are they using LEDs on the PlusSix? If so what is the size and who is the supplier?
Peter, yes, fully LED it's part of the BMW CANbus You can just make out the multi LED pattern in the rear lights here (apologies for the poor photo quality) ![[Linked Image]](https://www.tm-img.com/images/2019/09/09/20190907_112111_resized.jpg) If they are CAN bus then they should not be used on a trad that does not have CAN bus. If anyone gets the chance to have a good look at them I would like to know the diameter and the manufacturer so that, if they are the correct diameter, I can try to find out if non CAN bus versions are available.
Posts: 35,791 Likes: 471
Posts: 35,791 Likes: 471 |
........ the idiots that drive around in clear conditions with their rear Fog Lamps on are a real pain so hopefully these won't be too bright. Isn't that actual against regulation. On some cars it makes it less likely that a brake light will be observed. I find the idiots that constantly have the front fog lights on annoying too. I am not sure how it is now but certainly a few years ago there was no obligation to control the "aim" of fog lights for an MOT or similar inspection so sometimes they are aimed way too high. Yes missing the rear brake light is the concern, I have a feeling that front or rear fogs being on unnecessarily is a minor transgression of some sort but driving around you couldn't guess. Our traffic officer has not made an appearance on here for a while after the sad demise of his car, he would put us right. The front fogs aiming I haven't a clue I never find them necessary on our tintops and chose not to have them on the Morgan as I don't like the cluttered look and subscribe to the Colin Chapman school of performance.
Posts: 922 |
[quote=Gambalunga]What I would really like would be complete LED replacements for all the brake, position and indicator lights. Not just replacements for the bulbs but for the complete units. The originals are really quite crappy. The only problem is that Morgan seems to use a size that is not all that comon. 73mm and 95mm diameter replacement LED lamps are readily available but Morgan uses lamps that are about 82 mm or 3 1/4 inches diameter. The plinth is 84 mm or 3 5/16 inches diameter. Nobody seems to make replacement LED replacements in this size. I have considered gutting the existing units and putting 73 mm lamps inside them. I'm also considering this as a future project. Some of the modern LED sidelight, brakelight and indicator units are well put together a look to be fully sealed against the weather. Just a case of figuring out how to mount them to the car and retain the style. Kevin
Kevin
[quote=Gambalunga]What I would really like would be complete LED replacements for all the brake, position and indicator lights. Not just replacements for the bulbs but for the complete units. The originals are really quite crappy. The only problem is that Morgan seems to use a size that is not all that comon. 73mm and 95mm diameter replacement LED lamps are readily available but Morgan uses lamps that are about 82 mm or 3 1/4 inches diameter. The plinth is 84 mm or 3 5/16 inches diameter. Nobody seems to make replacement LED replacements in this size. I have considered gutting the existing units and putting 73 mm lamps inside them. I'm also considering this as a future project. Some of the modern LED sidelight, brakelight and indicator units are well put together a look to be fully sealed against the weather. Just a case of figuring out how to mount them to the car and retain the style. Kevin If the existing plinths are 84mm in diameter and you can get lights that are 95mm, one simple solution would be to get some sleeves to go over the existing plinths to match up with the larger size lights, the easy way to do this would be to use a 3D printer. That way you could print sleeves with the necessary 5.5mm wall thickness so they could be fixed over the existing plinths, retaining the original body fixings.
