Topics49,850
Posts837,435
Posts: 557 |
Thanks KankeL , the wheel weights don’t want to stick so a rebalance after the spot is cleaned with acetone is happening today. Thanks KankeL , the wheel weights don’t want to stick so a rebalance after the spot is cleaned with acetone is happening today. Try using Dynabeads, no ugly weights on your brand new finish ;-)
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
So MWS is just a conduit for parts into the UK.
Thanks Rog
MWS do have a manufacturing and rebuild facility in the UK, but presumably it is cheaper for them to source where labour is cheaper.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I thought about the dry beads but thought it was something that could work it’s way into the valve stem. Probably just thinking to much but I believe that Murphy is on the payroll.
Posts: 1,943 |
When I bought 72 spoke wires for My DHC I wanted Powder Coating. Dayton Wire Wheel suggested painting instead. Mine are painted, by Dayton and look good and seem to be holding up just fine.
Button
Posts: 557 |
I thought about the dry beads but thought it was something that could work it’s way into the valve stem. Probably just thinking to much but I believe that Murphy is on the payroll. I was very skeptical, but they do work. Ran them for a long time on my bmw k1600gtl.
Next tire change, or if I need a rebalance I will try them.
