11 members (Mats, Julian BB, Mr K, Biggle, JMcL, Sir Percival, mph, Bitsobrits, John Winn, Burgundymog, BobtheTrain), 367 guests, and 51 robots.
+8Rich 81
Topics49,859
Posts837,504
Jonny72
Page 4 of 8 1 2 3 4 5 6 7 8
Originally Posted by Arwyn Williams
I tried the MGOC tool once, it disintegrated by the time I got to the 3rd wheel. Ended its days in the wood burner.
As clumsy as I can be, I've never managed to damage either the spinner, the wheel, the car or myself when using a lead hammer when taking a spinner off!
Arwyn
Not to be confused with the hand operated, long pressed steel two eared spinner tool they also offer although it does require a little filing to suit Morgan spinners.
X
xc68anc Offline OP
X
Sorry about the confussion.
My Mog hasn't eared spinners. In cause of the strange regulations in Germany only eight flange nuts are fitted.
I think some of the good tools doesn't work (at my car).
René
2018 plus4 (sports green)
SFG Offline
I pour hot water on the nuts and they come of easily. I keep a tin bucket in the car so that I can drain hot water from the radiator at the roadside. I jack up the front of the car the do this. Sometimes I have to whack the radiator drain tap with the copper hammer, but it saves damaging the wheel nuts. I have to carry a gallon of water to refill the radiator, together with a pint of anti-freeze. It pays to be prepared.
SFG
2012 4/4 Sport
Originally Posted by Hamwich
Originally Posted by PHZI
please stop hitting spinners with hammers!
Err, but that's exactly what they were designed for. Spinners came about so that you could quickly tighten or loosen wheel nuts with a hammer. This idea that they should be kept pristine is what's wrong, not the notion that they should be used as intended. smile
I'm with you Tim,
After all they are called Knock On Wheels. Or at least Knock On Spinners.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Doesn’t that make your eyes water?
Costock, UK
Disco 5
SFG Offline
It does. But the anti-freeze acts like Wintergreen.
Happy Xmas Paul & Jan
SFG
2012 4/4 Sport
Good to know.
Merry Christmas Stuart and Heather.
Costock, UK
Disco 5
X
xc68anc Offline OP
X
Hot water from the radiator. I keep this idea for unhappy moments.
But I think this isn't my favorite. One thing: the cooling system works with a little pressure on it, than open the (expensive) radiator with a hammer to take care for a (not so expensive or in relation cheap) wheelnut?
Than refill the hot system with cool water...
I wasn't good in physic at school, but I think my teacher wouldn't be happy with this way.
After all the good ideas I take the factory (cheap tin pressed) spanner and weld a tube on it for the heavy moments
of strong tighened nuts.
René
SFG Offline
Not really a problem. You have to change the radiator every 5 years anyway.
SFG
2012 4/4 Sport
X
xc68anc Offline OP
X
Ups, good to know... But why are they so short living?
René
