5 members (sewin, Willowgreen320, Rog, High Hamster, Morganmike), 289 guests, and 58 robots.
+8Rich 91
Luddite 50
Posts837,967
#610330 30/12/19 09:47 PM
MOG42 Offline OP
Just wondered if anyone has suffered whine in neutral which goes when the clutch is pressed to the floor. It changes pitch if the engine speed changes - it sounds very much like a supercharger whine!
As it’s doing it all the time the input shaft is Turing I strongly suspect and input shaft bearing in the box as the compensator is always turning and so is the release bearing even with the clutch fully depressed.
Gearbox oil is clean, the magnetic plug is free from metal and I dragged a longer through the drained oil and nothing.
It’s done 40,000 miles now so it’s doing well!
Any advise welcome
Many thanks in advance and Happy New Year to everyone !
MOG42 #610353 31/12/19 12:50 AM
The gearbox is pretty robust, and in a Miata would last pretty much the life of the car. I would think the clutch throwout bearing would be a much more likely culprit.
Fortunately an inexpensive part, that is unfortunately very expensive to get to.
Late 2012 M3W
3Gs Offline
Best M3W quote, maybe ever...
3Gs #610359 31/12/19 01:53 AM
Indeed a good quote and very applicable to the things that go wrong with the M3W.
MOG42 #610367 31/12/19 05:39 AM
So you have checked chassis
Mine has done the same when Chassis Was cracked.
