6 members (Burgundymog, nick w, Luddite, TheRabbit, Robbie, John V6), 306 guests, and 79 robots.
+8Rich 77
Topics49,870
Posts837,673
Rudolf
#610703 01/01/20 11:22 PM
britmog Offline OP
Could anyone advise me on the ideal psi range for compression testing on a 1994 3.9 Rover engine?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Someone will come along to advise but memory tells me it's around 170-180?
Worth a google if not to confirm.
170 psi Minimum in my manual.
britmog Offline OP
Steve: I think I have answered my own question and you are correct. With a compression ratio of 9.35:1 the range is 170 - 180.
Thanks for the quick response.
Bruce
2013 M3W (Olga)
The S1 Roadster is 10:1. I compression tested the cylinders last week at 220 psi which I was told was fine.
It's not just the individual readings that are important, the variation between cylinders too. Ideally you don't want more than 10% variation. Of course lots of factors determine the ideal.
I remember way back when I checked a straight 6 vauxhall running on 5. Zero compression on one cylinder and running as rough as anything. Head off suspecting a burnt valve and found no piston or rod fitted and a jubilee clip covering the crank journal oilway. No wonder it was running rough!
SteveT #610802 02/01/20 02:07 PM
Did the owner lust after a 5 Cyl Audi perhaps ? laugh2
britmog Offline OP
Richard: Thanks, I'm running one cylinder at 178, one at 178.5 and the others at 179, so I think it's OK.
Bruce
2013 M3W (Olga)
Bruce, that's about as good as it gets I would say a nice healthy engine I am glad it's good news.
I've got the Haynes Land Rover Discovery manual that covers our 3.9 engines so if there is anything else you need just shout and I'll help if I can.
Hi. Probably sucking eggs, but don't forget to have the throttle fully open during the test.
