0 members (),
290
90
Topics49,870
Posts837,668
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Could anyone advise me on the ideal psi range for compression testing on a 1994 3.9 Rover engine?
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Someone will come along to advise but memory tells me it's around 170-180?
Worth a google if not to confirm.
Posts: 37,435 Likes: 978
Posts: 37,435 Likes: 978 |
170 psi Minimum in my manual.
Steve: I think I have answered my own question and you are correct. With a compression ratio of 9.35:1 the range is 170 - 180.
Thanks for the quick response.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
The S1 Roadster is 10:1. I compression tested the cylinders last week at 220 psi which I was told was fine.
It's not just the individual readings that are important, the variation between cylinders too. Ideally you don't want more than 10% variation. Of course lots of factors determine the ideal.
I remember way back when I checked a straight 6 vauxhall running on 5. Zero compression on one cylinder and running as rough as anything. Head off suspecting a burnt valve and found no piston or rod fitted and a jubilee clip covering the crank journal oilway. No wonder it was running rough!
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
I remember way back when I checked a straight 6 vauxhall running on 5. Zero compression on one cylinder and running as rough as anything. Head off suspecting a burnt valve and found no piston or rod fitted and a jubilee clip covering the crank journal oilway. No wonder it was running rough! Did the owner lust after a 5 Cyl Audi perhaps ?
Richard: Thanks, I'm running one cylinder at 178, one at 178.5 and the others at 179, so I think it's OK.
Richard: Thanks, I'm running one cylinder at 178, one at 178.5 and the others at 179, so I think it's OK. Bruce, that's about as good as it gets I would say a nice healthy engine I am glad it's good news. I've got the Haynes Land Rover Discovery manual that covers our 3.9 engines so if there is anything else you need just shout and I'll help if I can.
Posts: 122 |
Hi. Probably sucking eggs, but don't forget to have the throttle fully open during the test.
