Topics49,851
Posts837,442
Posts: 222 |
Chaps,
does anyone know what the 5 stud pattern for the wheels on a Series 2 are, and what the offsets are?
I would quite like a spare set of alloys for the car, and different to the Morgan standard ones (I was thinking some BMW CSL replicas in black, for trackdays etc), but have no idea what to order...is the pattern the same as for a BMW 5 series, for example?
Help!
Posts: 11,526 Likes: 312
Posts: 11,526 Likes: 312 |
You might want to PM Shooter as I believe he purchased some aftermarket wheels for his S4. In addition to this Millers and CerealSurfer are usually most helpful on the more detailed elements of the greasy bits.
Posts: 222 |
Thank you! Will e-mail SHooter and give Millers a call.
Posts: 2,562 Likes: 89
Posts: 2,562 Likes: 89 |
Harry, I think Shooter put his PCD and Offsets on Talkmorgan somewhere.... you might find them if you're nifty with the search function. Alternatively Shooter will be able to tell you directly.
Personally I don't have this info, but I'm sure the factory would tell you if you gave them a ring.
I do seem to recall the offset is not easy to get hold of.
Some aftermarket wheel companies do have the Morgan Aero listed... so probably have the information you are after already.
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
Harry its easy to find and many of the wheels marked as suitable are only available as 19inch. I've looked but in the absence of a decent after market shop locally its been a slow process. If you do find out could you publish in the info.
Slowly going green
