3 members (Rog G, Zach, DCH),
213
38
Topics49,911
Posts838,147
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
I' ve got a 2018 +4 with the easyup hood.
No unusual noises up to 130KM/h than it gets a little bit loud. At 130 KM/h you can have a talk with your passenger with normal speaking.
And it's nearly waterproof.
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
I have a studded vinyl roof. Some points that help fitting: Use hood swivel pivots to release tension when fitting. Then reset to tighten. Make sure the lip on the front sits ABOVE the screen frame. Push the lift the dot fittings fully onto the studs, being careful not to stress the screen. If you have leaks then fit extra sealing strips under the front edge. I use self adhesive strips. The front corners of the hood can curl up a bit which affects airflow causing noise. Not as easy to cure though.
Posts: 5,587 |
All the hoods are noisy compared to any tintop , if your are used to it then its part of the Mog experience !
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
Make sure the lip on the front sits ABOVE the screen frame. [/quote] Well I didn’t know that !
SFG 2012 4/4 Sport
All the hoods are noisy compared to any tintop , if your are used to it then its part of the Mog experience !  I' ve got a 1991 Classic Mini, "as from factory", standard exhaust, carb, aircleaner housing, soundproofkit. At 60mph it's more noisy in the Mini than in the Mog. ;-) René
Posts: 72 |
All the hoods are noisy compared to any tintop , if your are used to it then its part of the Mog experience !  I' ve got a 1991 Classic Mini, "as from factory", standard exhaust, carb, aircleaner housing, soundproofkit. At 60mph it's more noisy in the Mini than in the Mog. ;-) René I disagree my TR4A an Sprite hood caused very little wind noise as does my wife's MX5. There are a number of different hoods and methods of fixing for a Morgam just because one method dosnt cause a problem it dosnt mean another does not. Before buying my Morgan l tried a number of different cars with both the hood up and down and didnt have a problem but didnt test my model with the hood up. All l was asking was if anyone who has the same model as me also experience the same problem
2006 4/4 70th Anniversary Edition 2004 3.2 Audi TT Quattro
Well I didn’t know that ![/quote] [quote=SFG] No really, I didn’t know, thought it just sat behind.
SFG 2012 4/4 Sport
