5 members (Aeromax51, Dougie, Oliemog, Stevo666, Craig Jezz), 287 guests, and 28 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,145
Bervie1 Offline OP
Seat belt refitted without to much trouble, helpful neighbour assistance was again utilised to manipulate two spanners at the same time and a cranked spanner as per Roady’s picture was a great help.
The bolt was a tad awkward to get back in, I dropped it and ended up having to take the tool tray out to recover it after that I put a duster in place to catch it if it dropped which it did several times. To get the nut on I put a bit of duct tape over the bolt so I didn’t push it out again while trying to get the thread started which seemed to work quite well.
It isn’t a five minute job and a few profanities were uttered along the way but it is doable.
Just an update from me:
In a VW forum I found a tip against slowly retracting seat belts.
They recommended spraying the belts with a spray called "TUNAP 104".
I tried it out: The belts roll up much better now - not perfect but much better!
The belts look normal, the spray dries completely but the belts seem to be a bit smoother.
No connection to the manufacturer only a happy customer...
Worth a try, my MX5 has very slow seatbelt retraction. Ordered some and I’ll see how it works.
I am curious what your experiences will be!
I have ordered some. Will let you know
The stuff arrived & it seems to help. The belts retract a lot faster.
Hello John,
I'm glad it helps you too.
thumbs
Tried it too but for me, a very marginal improvement. In my case, weak springs are the real culprit rather than drag.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Has made an improvement, not perfect but acceptable. It’ll be interesting to see if the improvement lasts.
My seat belt springs are fine but find that the folded hood stops it from retracting back if I lean forward then sit back.
2004 Series 1 Roadster
