5 members (Black Adder, MATTMOG, RedThree, Morganmike, stumog), 217 guests, and 27 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,037
#614338 28/01/20 04:18 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
So today I jumped in only to find water pooled on top of the transmission tunnel in between gearstick and radio.
It’s a 2000 Plus 8. Any thoughts, or recognised problem leaking facilities ???
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Viper #614339 28/01/20 04:31 PM
Dribble some Captain Tolleys creeping crack cure around the screw on the rear bonnet hinge.
They also leak around the washer jets and wiper spindles. If you feel brave enough, drop the dash and look inside.
Viper #614340 28/01/20 04:33 PM
I've got exactly the same on my 2000 4/4.
Tried Captain Tolleys Creaping Crack Cure around the windscreen rubbers and the wiper bosses but although I think it improved things, I still have the problem.
My worry is that the fusebox is directly under the leak and I'm sure it does sometimes get dripped on.
I've sprayed some ACF 50 around it but I would like to find a permanent solution.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Viper #614345 28/01/20 05:25 PM
Mine was loose washer jets.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Deejay #614372 28/01/20 07:53 PM
I replaced the rubbers on the jets and fitted rubbers top and bottom
Viper #614373 28/01/20 08:01 PM
Also check the washer tubing, the OE stuff was crap....
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Viper #614389 28/01/20 09:33 PM
Not sure if this post refers you having been out in the rain or if the +8 was in the dry when you "jumped in", if the latter then check the heater hoses.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Viper #614417 29/01/20 09:03 AM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Thanks chaps.
Was pretty sure it couldn’t be the rear hinge as though that screwed into wood?
Britmog. Car sat in the rain.
I’ll try and splodge some gear around the spindle and jets. Thx guys
2002 Aero 8 S1
Viper #614418 29/01/20 09:05 AM
The rear hinge is very common, because some get drilled right through.
Viper #614442 29/01/20 01:36 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Rear hinge is fairly well sealed up and has the short flat screw heads not posi which I believe go right through.
The only other bit being the centre wiper spindle which I have just splodged up. The other wipers and the squirty things I feel are outside the area of concern.
I know water travels but it’s definitely coming from the middle
2002 Aero 8 S1
