2 members (Zach, DCH),
222
33
Topics49,911
Posts838,147
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
So today I jumped in only to find water pooled on top of the transmission tunnel in between gearstick and radio.
It’s a 2000 Plus 8. Any thoughts, or recognised problem leaking facilities ???
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Dribble some Captain Tolleys creeping crack cure around the screw on the rear bonnet hinge.
They also leak around the washer jets and wiper spindles. If you feel brave enough, drop the dash and look inside.
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
I've got exactly the same on my 2000 4/4.
Tried Captain Tolleys Creaping Crack Cure around the windscreen rubbers and the wiper bosses but although I think it improved things, I still have the problem.
My worry is that the fusebox is directly under the leak and I'm sure it does sometimes get dripped on.
I've sprayed some ACF 50 around it but I would like to find a permanent solution.
Bob
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Mine was loose washer jets.
Posts: 51 |
I replaced the rubbers on the jets and fitted rubbers top and bottom
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Also check the washer tubing, the OE stuff was crap....
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Not sure if this post refers you having been out in the rain or if the +8 was in the dry when you "jumped in", if the latter then check the heater hoses.
Thanks chaps. Was pretty sure it couldn’t be the rear hinge as though that screwed into wood?
Britmog. Car sat in the rain.
I’ll try and splodge some gear around the spindle and jets. Thx guys
The rear hinge is very common, because some get drilled right through.
Rear hinge is fairly well sealed up and has the short flat screw heads not posi which I believe go right through.
The only other bit being the centre wiper spindle which I have just splodged up. The other wipers and the squirty things I feel are outside the area of concern.
I know water travels but it’s definitely coming from the middle
