4 members (britmog, BobtheTrain, vbalddave, Socalm3w), 287 guests, and 57 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
Page 3 of 6 1 2 3 4 5 6
RobCol #613532 22/01/20 11:30 AM
Also try Heart of England
Chilliblu #613548 22/01/20 01:25 PM
Originally Posted by Chilliblu
Originally Posted by Fuel.inj
I’m sure Heart of England still do the bonnet stay kits.
https://www.heartofenglandmorgans.co.uk/search?type=product&q=Bonnet+stays
Had those on previous Mogs before Wolf existed, worked fine
Do these one's lock? I have been waiting for Wolf's bonnet stays for some time. Looking for an alternative that locks so wind can't blow the stay off. Had a couple of close shaves at car shows in the past.
I used to open the catch & trap the end in the extended spring, release & It used to stay put
RobCol #613554 22/01/20 01:50 PM
SBM Offline
I'm with Budster..
The Mk1 flexible stay arrangement.
It's a Morgan..!!
RobCol #613968 25/01/20 07:20 PM
First time attempt uploading pics so fingers crossed. These show my home brewed bonnet stay arrangement using 6mm rod end bearings and QM5 quick release spring loaded ball joints from Bearingboys. Plus 6mm aluminium rod and some fabricated aluminium brackets. Once in place the ball joint fixes firmly to the rod. Total materials cost is less than £20 a pair.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
RobCol #613980 25/01/20 09:07 PM
RobCol Offline OP
Great photos Chris!
Rob
RobCol #613993 25/01/20 10:22 PM
Cheers Rob.
Fabricating improvement items in the garage for the Morgan is a great substitute for what I used to do on the race bikes!
Chris
RobCol #614010 26/01/20 08:47 AM
I love the spring loaded ball joints idea, I'm going to convert mine to this.
1972 4/4 2 Seater
RobCol #614033 26/01/20 11:40 AM
My simple solution:
RobCol #614700 30/01/20 11:09 PM
Most professional and independant fixed bonnet stay solutions appear to employ the fixed lower rear bonnet catch (bolted to top inner edge of wing) and its matching spring loaded catch bracket on the bonnet to support same when open. This would work fine on my 3.7 Roadster for the nearside, but drivers side (RHD) has an extended bulkhead that requires a flat lower catch bracket bolted to the outside of footwell housing, the holes for which can be seen below adjacent to thin red line mark on wing.
This precludes attaching the pivoting bonnet stay to the inside of this lower catch as with nearside. Thoughts are to drill a hole above this bracket to support the bonnet stay pivot with large spreader washers each side to add support from the thin aluminium, subject to access and clearance when bonnet closed of course. I just wondered if anyone had come up with an alternate solution for this particular model.
RichardV6 #614704 30/01/20 11:51 PM
Hi Richard,
Could you have a right angled section brazed/welded to the right hand side of the catch plate. It doesn't have to accommodate a fitting as elaborate as used by Themorganeer, just wide enough for a small ball joint and long enough for stability?
Or, a wider section bolted to the face of the catch bracket (using original holes) again extending far enough to fix the ball joint.
Just thoughts.
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
