6 members (RichardV6, Fuel.inj, Barkingdog, John V6, bmgermany, +8Rich), 216 guests, and 49 robots.
+8Rich 83
Topics49,860
Posts837,491
Jonny72
Page 3 of 4 1 2 3 4
kankeL #616984 12/02/20 10:54 PM
Thanks for the oil and tank info Calum. I amended my prior post a to ask a question about hose barbs.
kankeL #616986 12/02/20 11:18 PM
I've edited my last post to add a bit about the barb.
RedThree #616988 12/02/20 11:46 PM
What was the deciding factor for the 1.5mm hole? I can see if there is a restrictor in the venturi end to keep oil from gushing into the venturi that would make sense but why restrict it going all the way up to the catch tank?
The sheer amount of oily air that blasts in and out of the catch tank if you don't have some restriction in the line covering everything in oil is impressive. To block the vent completely would likely cause big pressure swings in the crankcase which might/would blow out an assortment of seals. Putting a couple of restrictions in the line still allows decent venting but breaks the vent down into chambers to try and knock more of the oil out of the vented gasses before they get to the atmospheric vent filter on the top of the tank. The 1.5mm drilling was to more or less match the restrictor that S&S have in the manifold fitting.
kankeL #617030 13/02/20 10:56 AM
" Got over a litre of oil out of the sump and it was still trickling at a noticeable rate" that's a lot you may have a pump problem , a one way case breather may help
kankeL #617056 13/02/20 12:51 PM
WOW!.... you are getting a liter up in the can. I wonder if there is a way to just drain it back into the oil tank
Rodger
2004 Plus 8 (wife's)
rcmatt #617062 13/02/20 01:07 PM
I was thinking the same thing since that location is at or above the oil return line to the main oil tank.
There are catch cans with an inlet and outlet and separation baffles.
kankeL #617090 13/02/20 03:26 PM
Calum my puncture kit lives under the steering column on a piece of grip mat. I have a Lidl fishing bag with small tools, WD40 cable ties etc sitting on grip mat where your kit sits. Do you keep the "auxiliary" car on the fuse cover fuelled up ready to get you home?
RedThree #621360 07/03/20 06:07 PM
Have you thought about venting the oil tank so pressure in it is not blowing oil into the cam chest?
I am working on a couple of ideas. An item that will vent the tank AND add a tall sight glass to the tank so I don't have to use a wrench to remove the oil cap just to peer inside.
Put the sight glass on this end of the tank.
kankeL #621948 10/03/20 05:52 PM
Curious about the oil tank. What is the hose size coming off the barb on the engine?
2017 M3W Sport Green
Page 3 of 4 1 2 3 4
