9 members (Image, Heinz, tezzer, linklaw, Ian Wegg, Barry M, +8Rich, hillclimber, JohnHarris),
206
87
Topics49,848
Posts837,403
Posts: 960 Likes: 21
Posts: 960 Likes: 21 |
As a very young man I worked at a car dealer after school and weekends, washing and detailing cars. One of my peers was the lot boy, moving cars between sales locations and doing tasks such as ensuring the fluids and tires are full. The first time he was asked to top up transmission fluid, he somehow worked out that the brake fluid reservoir was the place to pour.....
Never underestimate human ignorance. The water in the oil may be from a well intentioned but ill informed dealer employee. +1 I guess the problem is human… Because I can't see how water can mix with oil in a properly closed oil circuit feeding an air cooled engine... sounds so weird!
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I suppose that some wingnut could add water to the sump tank thinking it was part of a radiator system since it sits where a radiator might go, if it had one.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Not sure I would take my M3W back to that dealer
Posts: 450 Likes: 1
Posts: 450 Likes: 1 |
This is a good read - it refers to industrial as well as automotive DIY oil analysis - not all relevant but some useful stuff:-
Fitch, J.C., “The Lubrication Field Test and Inspection Guide” Noria Corporation 2000
Good article Phil. Without a lab nearby these are good ways to check your oil quality.
So today I was checking my oil and noticed this. It is very small but I would call it moisture in the oil getting foamed. ![[Linked Image]](https://www.tm-img.com/images/2020/02/07/F75D03B0-8F24-412D-815F-F9DD20D59298.jpg) This is after 300 miles since the last change. I park in a heated and insulated garage.
I’m sure your right! How about condensation and lots of short trips so the engine doesn’t get hot enough to evaporate the moisture. The short trips not allowing the oil to get hot enough to burn off condensate is real. The oil tank on the Three Wheeler is very large and it is Morgan’s way of cooling the engine oil. Not a very efficient wat to accomplish that task. If you are using an oil cooler without a thermostat you have no way to maintain a constant more even oil temp I noticed that it takes me driving for almost 10 miles with the last half at freeway speeds for the oil to reach 180f. I would bet that the more quickly the engine reached a good operating temperature the better for the engine, and less condensate. If you have a regulated oil cooling system on the engine you can reduce the amount of oil in that massive tank so the oil heats more rapidly. Having vented the tank and experimenting with the foam separating in the tank using a separation system I can easily maintain the engine at 180f with4 quarts of oil in the tank. No condensate/foamy puking is pushed into the catch can in any volume. ![[Linked Image]](https://www.tm-img.com/images/2020/06/19/6D0F7EFC-432F-4942-A5DE-914D1877CC64.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/06/19/935D5655-C3E8-41FA-9846-DACC6A4964D0.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/06/19/7151FD7A-697A-4F5B-BE54-7A59FCE7FAB4.jpg)
