1 members (+8Rich), 328 guests, and 36 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,087
Page 2 of 4 1 2 3 4
No two the same - sounds ideal for a Morgan!
Pete
dodgy knurling practice makes perfect!
Triumph Herald 1969 13/60
Morris 1970
miles of smiles
miles of smiles
Great work Calum, any fool can make four the same, but to make them all different takes a different level of skill altogether! laugh2
Looking forward to summer and hopefully I’ll bump into you someday for a catch-up while out Morganing.
Originally Posted by rcmatt
just remember to not wear a tie whilst using the lathe
Or any loose clothing.
For a first attempt that is an excellent job👍👍
I have never seen tartan knurling before, well done smile
From the dim and very distant past I have memories of being told that twin tube fluorescent fittings were used above lathes to avoid the possible stroboscopic effect , a risk was that if one tube failed could create the appearance that the chuck was stationary. Nice work Calum, I would not know where to start.
TBM Offline
I did something similar a few years back and bought a combined lathe and mill (only a Clarke, but reasonable quality and small and light enough to fit in my shed).
Hours of endless fun creating swarf, but has proved invaluable at producing washers and spacers for my various collection of bikes smile
Haven't bothered with cutting threads - by the time I'd set all the gears up properly, I could have run a die down it. However I am tempted by a bit of knurling now!
TBM Offline
Here it is, a cheap option for the hobbyist - got mine secondhand for under £500.
Along with my trusty Myford, which I don't use anything like as much as I'd prefer, I also have one of those dinky liitle Peatol/Taig milling machines, which also gets little use. But when you do need them, they are fantastic. I made the wheel balancing cones on the lathe and my brake light brackets on the mill, along with loads of other brackets, spacers, strange bolts and such. Because all the threads I ever seem to need to cut are in conventional sizes I tend to use Dies, but I have done some on the lathe. Not as easy as it looks!
WW11 MOG
WW11 MOG
Well done Calum 👍
Got myself a 1950 Colchester lathe off an old Morgan racer last year, and like you I moved it by myself from the trailer to my garage. I’ve never moved anything as heavy in my life. My engine crane and a very sturdy trolley showed their true value
I’ve not got round to switching it on in anger yet, but I’m looking forward to making some very expensive washers 😂
Page 2 of 4 1 2 3 4
