3 members (PaulG, piquet, Ian Wegg), 268 guests, and 83 robots.
+8Rich 80
DaveW 51
Topics49,866
Posts837,595
#617965 18/02/20 02:25 PM
DanT Offline OP
I have a. 98’ +8 and wish to remove passenger airbag. Anyone have a guide to doing this? I am refinishing dash and want to memove it. Thanks
DanT #617966 18/02/20 02:34 PM
Make sure you inform your insurance company. Plus you will have to get the SRS module reprogammed to overcome the missing airbag.
Martin (Deano)
deano #617968 18/02/20 02:41 PM
DanT Offline OP
Ah good point
DanT #617987 18/02/20 05:48 PM
Formerly known as Aldermog
Airbags are small pyrotechnical devices. Working with them requires specialist knowledge, unless you want it to go off in your face....
Do you plan to re-fit the airbag once the dash has been refinished, or do away with it completely?
If you have a steering wheel airbag then as Martin said, the SRS module will need to be told.
Or do you plan to remove both and fit a more attractive steering wheel? If so you can probably have the SRS module removed as well.
Morgan Park in Hamburg, Germany, know all about this, some of the UK dealers also.
DanT #620720 05/03/20 03:28 AM
Instructions can be found on the GOMOG web site. The steering wheel A/B is a stand alone unit.
It's quite straight forward.
Dave
98 +8 Corsa Red
74 MGB Red
