9 members (SEG, SailingTom2, AlyMatt, boxboxbox, meabh, PaulV, Graham, G4FUJ, riri, WR142LLJPN), 193 guests, and 50 robots.
+8Rich 96
Luddite 52
Topics49,904
Posts838,076
Page 3 of 3 1 2 3
The other thing you can do is check the voltage difference between the battery terminal and the engine block while starting.
If there is a problem with the earthing, you'll get a potential difference while current is passed.
Toucan Offline OP
Thanks all.
I added a new earth strap between engine support and chassis. I cleaned all contact l could trace between battery and starter and chassis and battery. Then I changed points and condenser and distributor head and tuned static advance. When temperature was 3 deg C, 5 seconds were needed to start and now at 10 -12 deg C this morning was nearly immediate. I still suspect starter solenoid to include some resistance due to old age...
l am still looking for the earth strap between gear box and chassis!
Toucan 1981 4/4 Kent
Well done. I am glad to see it has improved.
Toucan Offline OP
Warmer weather helped also !!! Thanks
Page 3 of 3 1 2 3
