10 members (Graham, G4FUJ, Jon G4LJW, Morganmike, nick w, bmgermany, MATTMOG, Hamwich, RedThree, Mogdavid, MJF), 219 guests, and 32 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
Grumpy2 Offline OP
Anyone done it - found a nice kit from amazon. Has two separate heat pads, one for the base and the other for the back.
I'm assuming they fit between the cover and the foam which is OK if you're making the seat from scratch (which I was considering) but what about on a ready made Morgan seat? Remove some clips and slide the pad inside I assume.
Thats in advance
ps - yes I'm a bit nesh!
E
E
I know plenty of people doing it with older MX5's with no issues but Morgan seats will be different just because they can be!
The leather cover unclips. I also know people have easily fitted the Librands inflatable lumbr support by pushing in under the leather & above the foam.
You need to be careful routing the wires so the seat won't crush them if moved backwards on the runners.
https://www.gomog.com/allmorgan/interiorindex.html
Grumpy2 Offline OP
Hi John, seen the gomog item but the link is orphaned. Goes nowhere unfortunately.
Might have a look when it warms up a bit! Bit paradoxical, being too chilly to fit heated seats!
Gary
Grumpy2 Offline OP
Had a start tonight
I've got two pads in (just) and now need to fit some wiring - anyone with ideas on where I can find a switched and non-switched live under the dash? Non-switched needs 10 amps.
cheers
Cigarette lighter power supply or the clock
Grumpy2 Offline OP
Clock? - nah, don't have one of those, I did fit an accessory socket though. Forgot about that, cheers.
You can join the switched and non switched together and just wire to a fused acc. Live
Grumpy2 Offline OP
Some progress today but what a faff....
managed to get a non fused direct battery feed, now fused at 15A and a fused, ignition switched 5A feed for the relays.
Really pleased with the switch location, installed in the triangular gusset by the radio.
Now to repeat for the passenger side but first I have to turn the car round!
I've been using these rechargeable warmers in my Plus 4.
Giant BioGEAR GameWarmer: Rechargeable Battery Operated Heated Stadium Bleacher Seat Cushion. Lasts Up To 5 Hours and Also Recharges Cell Phones.
https://smile.amazon.com/dp/B00H1BCTXM/ref=cm_sw_r_em_apa_i_H0WwEb87AGAQB
65 Plus 4 / 4 Seater, car addict
