1 members (+8Rich),
295
Topics49,897
Posts838,018
Posts: 128 |
I have received a set of these for my Plus 4 from Morgan and unless I am doing something incorrect they do not seem to be a good and snug fit!!! At £37 they are not cheap, any suggestions? John 2011 Plus 4 (Marty)
Posts: 313 Likes: 1
Posts: 313 Likes: 1 |
I have rubber bonnet corner protectors and use transparent silicon sealer on the inside to hold them on. This helps but they come off eventually.
Posts: 40 |
I just put some white tack in them!
Don
1982 4/4 4 seater
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Always intrigued by these! What exactly are they trying to protect against, I wonder? I cannot see what would normally damage the bonnet corners. However, I would not be surprised if these things, acting as water traps, might cause damage in themselves. IMO, many better things to spend the hard-earned on.
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
I have received a set of these for my Plus 4 from Morgan and unless I am doing something incorrect they do not seem to be a good and snug fit!!! At £37 they are not cheap, any suggestions? John 2011 Plus 4 (Marty) Yes, put them in the shed. I have a set but never used them as they are an awful fit and as others say, more likely to cause more problems than they solve. My old MG’s had rubber ones which were fine but even these had a rivet through them to keep them in place. Unless you are doing something weird with your bonnet it’s highly unlikely you will damage a corner.
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Posts: 57 |
I have received a set of these for my Plus 4 from Morgan and unless I am doing something incorrect they do not seem to be a good and snug fit!!! At £37 they are not cheap, any suggestions? John 2011 Plus 4 (Marty) Assuming you mean the leather ones, I have had (and lost) quite a few of these over the years but all seem to get "baggy" after a while. They look great, especially with a matching bonnet strap. I have tried blue tac, double sided tape, velcro , but none seem to last. I have now given up on them!........unless someone has a better idea.
Rich Maroon and Ivory (ish) Plus 4 2015
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
Interesting in that I have used them since new, only at the front corners. Supposedly to stop paint chafe. Ah the paint has still been rubbed away, but is very shiny from being rubbed by the rubber.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Leather or neoprene patches stuck to the inside with DST on both surfaces work a lot better.
Leather or neoprene patches stuck to the inside with DST on both surfaces work a lot better. Agree, plus along the ‘curve’ where they rub the most.
