7 members (bmgermany, flyfisher, High Hamster, John Winn, JohnHarris, MartO, TalkMorgan),
214
Topics49,901
Posts838,046
Posts: 1,464 Likes: 99
Posts: 1,464 Likes: 99 |
You can join the switched and non switched together and just wire to a fused acc. Live problem with this is the possibility of leaving one or both switched on with the car engine not running - I think a flat battery would be the result. The kit I have uses the ignition feed to activate a relay to allow current to flow through the warming pads. Ignition off and no current flows so no flat battery. just re-read and you did suggest acc live, but on my fuse box that's not the easiest to find as it certainly doesn't follow any of the published diagrams. cheers
Posts: 3,564 Likes: 13
Posts: 3,564 Likes: 13 |
I'd be interested in the link to the Amazon site please. I've been thinking of doing this for ages, just haven't got around to it yet.
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
I can recommend them. Great for this time of year.
I'd be interested in the link to the Amazon site please. I've been thinking of doing this for ages, just haven't got around to it yet. not quite the same as mine, I bought mine a year or two ago for another project.. https://www.amazon.co.uk/Car-Heated...amp;pf_rd_t=BROWSE&pf_rd_i=303637031Very similar to this though
Posts: 1,112 Likes: 17
Posts: 1,112 Likes: 17 |
Are they easy to fit? Thinking the Reclining seat in a 1996 and 2007 car?
can't comment on the reclining seats, they are something I dream of but alas do not possess.
In the non-recliners fitted to my car they're relatively easy to fit.
Seat out, remove the trim clips, stuff the heating pads into the seat (gynaecology skills help here) and reassemble.
The wiring is relatively straightforward too.
Access is, however, dreadful. If you're bendy and agile you might be fine, I'm not and I'm still hurting!
