7 members (BLUE+4, John Wilcox, Ncik P, aerotaff, Ritchie B, Alistair, TeddyAds), 349 guests, and 93 robots.
+8Rich 86
Topics49,851
Posts837,443
#622886 14/03/20 09:29 PM
Landy Offline OP
I'm looking at swapping out the front indicators and inserting led spots. This will be after fitting blackout headlights that have built in indicators. First look at the indicators there is no obvious way to get in to them or remove them from their welded on brackets? Any thoughts before I look for my magnifying glass?
Landy #622899 14/03/20 09:51 PM
Landy Offline OP
I may have now found the answer [Linked Image]
Landy #622906 14/03/20 10:07 PM
The diagram above shows all you need to know, remove the screws 14 there are two on my car. The led unit can then be pulled out, the led unit is hard wired with the wiring feeding through the welded stud which holds item 1 on.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
