1 members (+8Rich), 360 guests, and 50 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
I have one per side on my 4/4 sport - no problems in 10 years with them I think they look good but also are a visual reminder to keep feet clear of the running boards and encourage lifting feet that bit higher - so fewer scuffs. Even if someone does stand on them - and I`ve only come across it a couple of times- it stops the running board being stood on and provides a bit of protection (they would probably have stood on the wing anyway!).
BobJ Offline OP
Mmmm. Bit of a mixed bag. Many thanks for the views. I think I’ll sleep on it a while.
2017 4/4 80th Anniversary
I once decided to take the rubber inserts out of the previous Mog, on the underside of the running boards all looked excellent due to years of regular waxoil, but after the inner ends of the tiny bolts were exposed wow ! The heads were just a mush of corrosion & looked like just mild steel
I replaced all with 316 stainless & 'Dr Dave' W used my photos for his Miscellany article
The ally channel just acts like a water reservoir & for me I would not by choice, have them again
+1. Changed fixings to correct length stainless and wax oiled thoroughly above and below before re-fitting, No doubt they have saved scuffs on drivers side.
ETA: original cad plated overlong screw's covered in underseal makes them a pig to remove but the operation could now be completed in a fraction of the time.
BobJ Offline OP
Right. Slept on it, procrastinated some more and then ordered a pair from BHM wink
Well done, style really matters thumbs
+1. Says the fat dishevelled man who would love to be neat & tidy. There is a Mr Men book in there somewhere
BobJ Offline OP
Would some kind sole with a long door 4/4 that has factory fitted wing treads (singles) do me a small favour please.
Now this favour is works on the assumption (possibly a little naively) that MMC have some sort of template for drilling the mounting holes for the wing treads rather than fitting by eye.
I am after three measurements please which are to the tapered tips of the treads:
Yellow Arrow - edge of the wing beading to the rear tip of the tread;
Green Arrow - trailing edge of the front wing to the rear tip of the tread; and
Orange Arrow - edge of the wing beading to the front tip of the tread.
I'm going down the 3M VHB tape route for fixing so the mounting bolts will be going. In a bit of a quandary as to what to do about the mounting bolt holes in the aluminium. Do I leave them in which case any water ingress will pool on the upper side off the tape which is waterproof so may not be an issue. Or do I try and seal them over? With rubbers fitted a small dab of clear silicone sealant squeezed into the hole from the underside and smoothed off? Any other ideas and suggestions gratefully received.
Many thanks in advance. Very much appreciated.
I have always thought that Stainless steel fixings on aluminium is a NoNo due to electrolytic corrosion of the aluminium ?
If this is correct then I would rather have the bolt holding the strip rust away than the aluminium fender corrode?
Cheers John
2011 4/4 - "Elrond"
2007 Elfin C3 Clubman - “Gimli”
Hi Bob
I have a 2008 4/4 with factory fitted strips. My measurements are:
Yellow: 51mm
Green: 72mm
Orange: 75mm
That’s assuming there are any two the same!
Pete
Demon Tweeks do a range of aluminium fasteners.... plenty of other sources as well ....don't have treads fitted on mine but from the pic it looks like that would be ... an ali to ali with ali fix which should minimise any possible corrosion probs
